Question about E-Machines eMachines Desktop PC
Replace power supply, part#py2200B001 LITEON PS-5221-06A1-ROHS
    Scholar:
  • 119 Answers
Im not understanding the question, can you please clarify a little more for us?
Posted on Sep 10, 2010
Blows fuse
If your Liteon 32276 power supply board is causing blown fuses, there are a number of things to try.
Try plugging into a different outlet in your house to see if the result is the same.If the result is the same, you may need to replace your liteon 32276 power supply board as it may be defective.
Apr 16, 2012 | Computers & Internet
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Dec 13, 2009 | Computers & Internet
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Computer does not turn on
you can try your power supply if it works by jumpering its pin. try to insert copper wire in pin 11 and connect it to pin 12. and turn o your power supply. But if it won't works then used tester and test its circuit boards particularly  is capacitors, resistors and even the transformer inside the power supply. Or if you can't make it then you can call a technician either in computer or electrical to test your power supply if it still working or not. In that wy can be sure in making decision if its really your power supply got problem or not.
Thanks
Jun 26, 2009 | Lite On (PA41519B1) 150-Watt Power Supply
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Liteon na115 mainboard can't display/load bios
1) Try re-seating the RAM
if it's still the same problem, then the power supply maybe bad.
Try with a good PS.
Jun 17, 2008 | Lite On NA115 Motherboard
E-Machines eMachines Desktop PC Logo
990 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
