Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
My pool pump is humming then turns off - AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
  • nmbrook Sep 09, 2010
    Thank you.
If the armature will rotate freely and the bearings are not frozen, then it's probably a bad start capacitor. They are not very expensive compared to a new motor so it might be worth replacing it to see if it's bad.
Posted on Sep 08, 2010
Testimonial: "Thank you."
  • 1 more comment
  • nmbrook Sep 08, 2010
    Where is the start capacitor located?
  • handyrentals Sep 08, 2010
    It will be under the metal cover that sticks out on the side of the motor. Usually removing one screw will allow access. There will be two wires connected to the capacitor. These capacitors are "bi-polar" so it doesn't matter which wire goes where. Do make sure all power to the system is turned off at the breaker box before servicing.
    Try Ace hardware for a replacement or any electrical supplly house.
    Forgot to mention that If your pump doesn't have a capacitor, then it uses a starter winding and centrifigul switch inside the motor housing itself. It is possible that the swich contacts have gone bad but more likely the start winding would be the problem. This would be a job for a qualified motor repair shop or a replacement motor.
If the armature turns freely replacing the capacitor will probably fix your problem. But something in the motor is causing the capacitor to overwork and burn out to begin with. Replacing a capacitor is a short term solution and the new one will likely burn out in a short time period.
  • Derek
    Derek Sep 18, 2010
    that's not true. it is possible but certainly not always the case. Capacitors can fail just like anything else. I have replaced many start caps and never had a second one fail before the motor itself finally gives out.
2 Suggested Answers
  • 623 Answers
SOURCE: am trying to open pool, motor hums but will not run
Sounds like COULD BE something (a small stone or twig) jammed in the impeller. See if you can spin it using a long screwdriver, if it moves, it is not jammed. If it spins, I hate to say it might be the motor is gone.
Posted on May 24, 2010
Testimonial: "good response, but have a follow up question regarding the answer I received - how can I pursue? thanks!"
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Apr 02, 2013 | Waterway Pool & Spa
Above ground pool pump humming
BLOW OUT THE BACK OF THE MOTOR WITH COMPRESSED AIR. THERE IS TRASH IN THE START SWITCH , AND IF YOUR LUCKY IT WILL FIRE BACK UP. IF YOUR IN THE LONGWOOD FL AREA I DO THIS FOR FREE FOR MY ABOVE GROUND POOL CUSTOMERS
OTHER SHOPS MAY DO IT ALSO, JUST CALL AND ASK
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL 32750. PLESE VOTE YES OR NO IF I WAS OF HELP
May 19, 2012 | Hayward Pool & Spa
Pool pump does not turn on it just hums
If it hums and the impellor shaft is not turning, it's jammed and will trip the breaker after it over heats.
If the impellor shaft is turning, may have a broken impellor. After closing the inlet and oulet valves, I would take the pump cover off and check... Good luck...
Aug 07, 2011 | Waterway Pool & Spa
Turn on pump and it only has a humming sound. Motor does not start
Check your start capacitor. Probably best to remove the motor and take it to your pool supply place.
May 14, 2010 | Pool & Spa
Hayward above ground pool pump will not start.
sounds like the windings in the motor are shot! but does it have a capacitor? if it does you could simply have a bad starting capacitor so don't let it hum for that will surely scar the windings
May 31, 2009 | Hayward Pool Products Economy 1 Hp Above...
Pump will not start and it just hums. When I
if it has been sitting since last year, some rust could have kept the shaft from turning. Get some pump pliers and try to rock the shaft. after you get it freed up, turn it back on.
David
May 09, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Motor hums when turned on
Try this link for help. They suggest emailing before calling:
http://www.mypool.com/introduction.htm
Feb 24, 2009 | A.O. Smith SQ1102 Pool Pump Motor
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
801 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
