Question about Coleman Mach III Air Conditioner
Just aquired a used mach 3 rooftop a/c for my tt. It was working last time previous owner used it. after install in tt, nothing comes on. there is power coming into thermostat and power running to the switch. I did notice the capacitor has been replaced before. any ideas? and yes the top unit is plugged into lower unit.
  • dcsmsxxx Sep 08, 2010
    This unit is self contained. There is no saddle valve or any other valve to pump out freon. There is only the top unit that sits on top of the camper and the bottom (ceiling control unit) is inside the camper. I was with the individual that removed the unit from his enclosed trailer. He used a generator to power it. He says you only need 30 amps to run which is specifically the amperage running the camper. Incoming power has been checked, control switch has been checked, and thermostat control - all have power. I have noticed that the run capacitor has been replaced. According to the Model Mach 8333A871, the capacitor should be 25 mfd 370v. However, the one that is on it is 25mfd 440v. I do know that as long as the microfarad are the same that the volts can be higher. There is also a fan capacitor which has the correct part # on it. Neither look swelled or have an oil coming out of them. The run capacitor has a black dot on it between the terminals. I need to know how to discharge the capacitor(s) to be able to do any further testing that you feel needs to be performed.
    Thanks
    President:
  • 1,515 Answers
Hi, this one will be difficult to trouble shoot with out being there, but there are some things you can check. You say there is voltage to the thermostat? This sounds like a power problem, or the unit is off on a safety. You have power going to both the unit on top and the indoor unit? I believe this is what you are saying. When this unit was removed, was any freon lost that you know of? If the unit on top was not pumped down which I believe on this kind of system, they are not set up with a pump down valve to pump the freon from the outdoor unit to the outdoor receiver unit so the top unit can be removed, the problem is its off on its low pressure switch because it has no freon in the system at all. The freon has to be recovered to remove the condenser from the roof, and when installed on your roof, it has to be evacuated with a pump and recharged. If it has pump down valves on the high side line, this valve has to be closed off while the unit is running, and the compressor will pump the freon into the condensers receiver. After it is connected to your indoor coil, it has to be evacuated and the freon has to be released by opening up the liquid line valve to let the freon go through the system. Both the indoor and outdoor lines ( freon lines ) have to be connected and the air has to be removed by a vac. pump to make sure all air and non-condensables are removed before the freon is let loose or it is charged to spec's. Don't worry about the run capacitor. I strongly believe this unit has not a drop of freon in it and I don't believe it has a pump down valve on the compressor, so the last owner either bled the freon into the air, or it has a valve on the compressor that you can look for on the smaller of the 2 copper lines. If there is, you should have the unit evacuated before you open this valve. If you want to open it and take a chance on it, turn the valve in like you are closing it, its the opposite of a water valve and the unit will start if there is freon in it. You may want to call this guy to see what he did and if he did pump it down to save the freon. It has to go somewhere when the unit is split apart. I hope the best for you, but this is the problem, it will not come on due to no freon or its in the receiver. Call him and find out what he did. Please let me know what you find out. Please rate me as I know you will be kind, and I will be here to help in any way I can. Keep me posted on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 08, 2010
  • 1 more comment
  • Robert Horton
    Robert Horton Sep 08, 2010
    Hi, just checking in with you to see what you have found out.
    Shastalaker7
  • Robert Horton
    Robert Horton Sep 09, 2010
    Hi I am sorry I have been at work and just found your comment. If the unit was running good with the generator at 30 amps, there is no problem with the freon. In fact, these units don't have to be pumped down or recovered as I was thinking of a residential unit at the time. As for the capacitors, just use a insulated screw driver to touch across the terminals and ground them out. You will hear them pop and see them arc if they are charged. Yes. you can go up in voltage from 370 to 440, but not on the microfareds. If this unit does not start up, there should only be 3- wires to connect if it is a 120 volt unit, Black, white and a bare ground into the j-box, and power cord to the indoor unit. If its 220 volts, not much difference. You may have a problem with the stat even though it has power. Just remove the cover and with the unit set to come on, take a piece of insulated wire and touch across the terminals of the wires on the stat, and if its faulty it will start. If nothing happens, put the cover on it.You can check the capacitors, but if the unit was running when you bought it, they will be fine. All you can doo, is make sure that all of the electrical is right, and the thermostat is working right, and it should run. Double check all of the power coming in where there is supposed to be, and the stat is what will bring it on. This may be your problem, even if it has power. Let me know what you find and we will get it going. It has to be a electrical problem, something tha'ts been over looked.. Keep me posted and I will check back more often now.
    Shastalaker7
  • Robert Horton
    When jumping out the thermostat, remove the cover and the sub-base to expose the wires. This is what you will jump and hold the wire on are the terminals to see if it starts. If it does, the stat is bad.
    Shastalaker7
Hi,my audi tt 2001 bose says fad off but how do you get the fader on ?ive tried every button ,also-some times the stereo volume works fine ,then a couple of hours later you can turn it on and it is VERY...
I have a 2001 Audi tt and I've read a tonnnn of columns about how to use the fader.... The best answer I've gotten is that because the tt cabin is so small, the fader has no use, and is basically just there to keep uniformity in the console. As for your second problem, that isn't happening to me. The only thing I notice is that my driver's side speaker is much quieter than the right side, but that is probably from overuse by previous owners. (purchased the car in May 2010)
Feb 24, 2011 | 2001 Audi TT
We have a Mach III coleman AC unit... a little
Sounds like the evap coil is dirty or its low on freon.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Air will not come on
hmmm..sounds like an amperage issue..what's the rating on those units. other thing..is plugging in at your place, is most likely hitting an invertor, which needs enough juice on back end to power those..check with the previous owner to determine what they did
May 31, 2008 | Dometic Rooftop RV Air Conditioner
Tomtom wont turn on
I had similar problem this morning. Last time I was using my TT was about 3 mths ago and it worked fine. 2day I switched it on, the first screen appeard but the, TT just switched off. I put my friends SC card and it started... . Looks like soft on SD issue.
I have a buckup file but at 87% it fails ... Lifes a ..... :D
My advice is to download and install new soft on your SD card but what about maps U/me bought with the TT?? Have no idea
Apr 26, 2008 | Tomtom ONE GPS Receiver
Can it be Fixed or just trash?
It can be fix, if you look here on the threads and see the fix is already here.
Feb 07, 2007 | Mitsubishi VS-6043 60" Rear Projection...
TT 200 Toastess Toaster
hi 1)yes - aluminum: solder, plastis: epoxy 2)yes if you got special gear for it 3) NO BUY A NEW 1 IT WILL COST HALF THE PRICE!! GOOD LUCK
Mar 22, 2006 | Toastess TT-200 Turnover Toaster
Coleman Mach III Air Conditioner Logo
170 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
