Question about Kenmore 80599 Microwave Oven
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their been problems with the switch that activates the lights? I push the switch, it shows in the LCD display HIGH, NIGHT, or OFF. But the lights (there are 2 of them), never illuminate.
  • Kenmore Master
  • 9,085 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on Sep 08, 2010
Testimonial: "Thank you for your prompt reply! You have confirmed what I had suspected and I will pass this onto the rental management company and your part fix. "
I have a Kenmore microwave mounted above my stove. The light that lights my stove is blown and I can't find the right replacement bulb. It has two little prongs that should fit into the unders
Are these little spot lights? About the size of 1/2 dollar round and maybe 1.5 -2 inches long? 2 prongs about 1/2 inch apart? Take one of those lights and show it to a local hardware dealer like "Lowes". There are may types and some are 12V some are 110V. Thats why I suggest showing to the local hardware guy.
Jan 12, 2015 | Microwave Ovens
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
Under mount light will not come on
Have you check the light bulb under your microwave oven? Maybe it gone north because it to hot under the microwave oven look at the top of kitchen stove. GB you... stewbison
Aug 21, 2011 | Samsung Microwave Ovens
THE STOVE TOP LIGHT ONDER THE MICROWAVE BLEW OUT. WHEN I REPLACED THE BULB BOTH LIGHTS NO NOT WORK.
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Light does not work even after changing the bulb this is the light that shines over the stove top (Kenmore Micro model # 721.80412500
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more information or to arrange repairs.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 10, 2009 | Whirlpool MH7135XE Microwave Oven
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
Bulb replacement
It aint haolgen. This is another GE piece of POO engineering.
Unplug the microwave FIRST.
Now, Make sure your stove top is cold!
There are 6 phillips head screws holding a plate that secures the stove-top light and grease trap filters on the underside of the microwave. Lay on our back on the cooking elements looking at the bottom and remove the screws. The plate should swing down on hinges in the back.
Then remove the "bulb holder" which is held inplace with another phillips head screw. You can see what it looks like: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100389
You should now be able to remove the "screw-in base" of the bulb with your hand or in my case, because I was so tight, I man-handled it with a pair of needle nose pliers.
Now, go find a bulb! good luck.
Nov 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 62709 Microwave
The 5-digit number above is not a complete model number.
If you can post the full model number I can probably give you a link to the explode view, or you can find it here: http://www3.sears.com (the 3 is correct)
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Nov 21, 2007 | Kenmore 62702 Microwave Oven
Kenmore 80599 Microwave Oven Logo
261 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
