Question about E-Machines E15T3 15 in. Flat Panel LCD Monitor
When using firefox the content is bigger than the monitor screen. how do i adjust the content horizontally to fit the screen?
  • 702 Answers
Did you try simply holding the Ctrl key and pressing the minus (-) sign? That will zoom the content to a smaller size.
Posted on Sep 08, 2010
The display does not fill the screen of the monitor. How can I fix this
It depends on the type of monitor you have. Generally you will have a physical menu button on your monitor. Depress this and look for Vertical and Horizontal adjustments using the arrow keys on your monitor. You can stretch the screen all you like to fit the diameter of your monitor.
Nov 19, 2013 | Envision H190L Monitor
How do i get the web page to fit the screen
You can make the web page fit your screen by adjusting the horizontal and the vertical adjustments of the monitor.
Nov 08, 2010 | Acer AL1916W 19" LCD Monitor
I am unable to adjust the screen to fit the monitor. The screen is bigger than the monitor and I cannot reduce the size using the menu buttons on the monitor. Is there anyway to use those options through...
Yes right click on the desktop and click properties, when the window comes up, go to settings, and set to say 800x600, and click OK, this may sort you out.
Also ensure you have the graphics manager installed too.
Aug 06, 2010 | LG Computers & Internet
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Apr 23, 2010 | Televison & Video
The screen is stretched there is nothing distorted
What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
May 29, 2009 | Acer AL2216WBD LCD Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My screen is x X y inches. The windows page doesnt fit into it. There is one inch of black space on the monitor on the left and one inch of my windows screen is lost on the right!!!!!!!
With the on-screen controls, select Auto-Adjust. This should set suitable defaults based on the incoming signal. If you are using the VGA connector and the position still needs to be adjusted, use the on-screen controls to shift the displayed image to the proper location (under Display Settings -> Horizontal Position).
Apr 17, 2009 | Dell UltraSharp 1908WFP 19inch Black...
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
My computer screen got bigger
Press Control and + to make it bigger
Press Control and - to make it smaller
Nov 14, 2008 | E-Machines eMachines Desktop PC
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
E-Machines E15T3 15 in. Flat Panel LCD Monitor Logo
47 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
