Question about Maytag Neptune MDE5500AY Electric Dryer
Don t count the time and the dryer not stop - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
Dryer 2 months old. Made a pop noise and stopped working on the count down. Won't restart. Panel is lit but the dryer won't function. Ideas?
Likely either a fuse or component on one of the control boards went. At 2 months old, why waste your time? Call for warranty.
Aug 01, 2015 | Maytag MGDE251YL Front Load Gas Dryer
My dryer will not shut down it only stop if I
Hi, im sure you have a bad timer .. most times it not worth the price and labor ..
Oct 03, 2014 | Dryers
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
Dryer stops before clothes are dry...have to wait a few minutes before it will start again but only stays running for a short time.
if the dryer is running and then the motor stops when it gets hot it sounds like you have a bad motor.when was the last time you cleaned out the dryer and vent line?also i need the model number,on some kenmore dryers they have even heat that can cause this to happen if it's in your machine the timer will count down faster than normal and shut down ,or you could have a bad thermister so send the model number and i can check it out for you.
Mar 26, 2011 | Kenmore Dryers
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
DRYER STOPS
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Oct 27, 2007 | Kenmore 63942 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
