Hello, i have an hp laptop. my family and i just moved and purchased a new wi fi router. my step dad's laptop can connect without a problem, mine will not. i've tried everything except completely wipping my laptop clean to get it to connect. what can i do? marisa
  • 567 Answers
Most computers connect to a WiFi network automatically.
Please make sure the wireless in your computer is turned on. There should be a button with an indicator light near your keyboard, just switch it on.
Alternatively open your start menu and find "network" or "internet connections". There should be an option for wireless that you can select. Wireless connections will be scanned and you will need to select from a list of options to connect to. Once you click it you will be connected to your home WiFi Network.
If your network has a password your will need to enter the Network Name (Called SSID) and the Password in the Wireless Connection Wizard.
This will resolve the issue you are facing.
I will look forward to your feedback and positive rating.
Posted on Sep 08, 2010
Why is My HP printer not connecting to Wi-fi?
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Aug 05, 2015 | HP Office Equipment & Supplies
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
How can get my wifi connections to my computer
things needed internet connection wi-fi router. wi-fi enabled laptop.
steps switch on router enable wi fi on your laptop check for availbale networks connect to the network. if asks key contact service provider
Jan 03, 2011 | Fujitsu Computers & Internet
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Connecting to internet
you connect the internet if your broadband router is wi-fi enable. so if you turn on wi-fi on your laptop and you get the signal. than you can access the internet on the laptop too. But for this your router should be wi-fi enable and DHCP must be set properly with in the router. so if you can access the router from your desktop by opening it in browser e.g. http://192.168.1.1 and default login id and password e.g admin you can check the status inside it. I hope this will help you in solving your problem.
May 10, 2008 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
