Question about Dell Precision Workstation 670 PC Desktop
No logical drive drives found dell presicion 670
    Guru:
  • 551 Answers
If the problem would be the logical drives not found it means that your drives are defective. Though it is working but the board on the drives does not. Replace the drives and then start the installation of your operating system.
Posted on Sep 08, 2010
Hi, I just bought this Dell Precision 670,and it shows: "No logical drives found" and then "BIOS not installed!" I am unable to understand what went wrong, or if the BIOS is really damaged. I don't know...
Power on computer and enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Aug 11, 2013 | Dell Precision Workstation 670 PC Desktop
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 RAID1 Install on Windows 7
The RAID configuration maybe setup in the BIOS settings.
Mar 31, 2012 | Dell Precision Workstation 670 PC Desktop
Dell 670 work station: constant conflicts in software that works on same OS in other computers. The Mr Fix it will not start. File Hippo utility to check drivers will not work. Some programs will not
Hi re the DVD drive issue , i suggest try accessing the computer manufacturer support site and ascertain whether they be a firmware update for the specific optical drive . Updating firmware will often correct disk issues
( do not update firmware for a retail same model drive )
Lets see , Dell 670 yes many firmware updates
also of interest to you would be the Dell Crash Analysis Tool ( can run offline) found in the driver download site
Is a start anyhow
ps - due to age 2005 ( but still a rocket for home office ) , i would update BIOS firmware if not done so
Sep 03, 2017 | Dell Precision Workstation 670 PC Desktop
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
Need internal drive for dell precision 670
You have two options with the WS670. You can use standard IDE (PATA) drives or you can use SCSI drives (up to Ultra320). If you are already using SCSI HDDs in the system, you would most likely be best served by sticking with SCSI for your hard disks and leaving IDE for your optical drives which I believe is the default configuration, but it can be modified when ordering the systems. If you are already using LVD drives, just go ahead and slap another one in of any size. If you want to use IDE, your maximum size will be dicated by the chipset used in the system (information not available on the Dell website).
Jun 09, 2009 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Sep 01, 2008 | Dell Precision Workstation 670 PC Desktop
Dell 670 BIOS not installed
If you are installing a new hard drive, it is possible that you have not connected the cables correctly. Check if these are seated firmly in the corresponding pins.
Aug 31, 2008 | Dell Precision Workstation 670 PC Desktop
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
466 people viewed this question
Alun Cox
