I have been given an older laptop Patriot 2433 and wish to upgrade the ram as only 256 meg. i cant find where/how to fit. and i would like to know how much and what type of ram i need please.
  • 22 Answers
Try Crucial. They have a neat little pulldown menu for choosing what you got, then it will tell you how many slots it has, whats the max and sell you what you need.
CLICK HERE
Posted on Sep 08, 2010
  • cludgate_49 Sep 08, 2010
    Thanks S1LV3R, i have already been there but they don't list my make/model
  • S1LV3R
    S1LV3R Sep 08, 2010
    Did a little more digging If it helps any. It was built by PCChips. 1gb max in 2x 512mb pc133 sodimms
RAM upgrade
You can actually add another 256, or a 512 or 1 Gig there depending on the type of RAM you wish to install.
If the rams are identical like all 1-sided or all 2-sided modules, they can work harmoniously. You can't just mix a 1-sided ram with a 2-sided ram.
But the safest way for you to do is simply bring your laptop to the store where you wish to buy the ram upgrade. There, you can readily test the compatible ram and buy it.
Jun 06, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Hi, I wish to upgrade my Ram speed from 256
Hi friend,
You can use more then 2GB Ram in your motherboard. it should be DDR-1 Ram .....you can change..
Dec 28, 2009 | Intel Motherboard
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
Why do my toshiba satellite only show 191 of ram when i have a 256 ram installed
There is nothing wrong. Your RAM may be special RAM that the computer uses some of the memory for something else.
Sep 23, 2009 | Toshiba 15.4-inch 1.6GHz 60GB Laptop PC...
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Memory upgrade for Compaq Presario 2195 us
This is helpful for process on changin ram.CLICK HERE
As far as i can tell your computer will hold up to 1024 megs of ram that is 2 512 sticks. Just pic up the other 512 and call it a day that way you know your maxxed out on ram anyway. Not sure if it will take the different size sticks as I haven't found anything on their site. TRY HERE
Jan 15, 2009 | Compaq Presario Notebook
FITTING EXTRA RAM INTO MOTHERBOARD
What you can physically fit and the space available is not the same thing, Crucial is an excellent site but it might say that you have the capacity to fit x megs but whether you have the empty slots is different (see the last paragraph), and you will not really know untill you open the case and look.
The actual fitting is simple enough if you can reach the slots without dismantling the whole machine!
Supposing you can clearly see and reach the slots, with the machine off, and the power cord removed - yes removed! Gently press on the white clips at either end of the fitted memory it will pop up, lift it out without touching the gold terminals, notice the slot in the bottom edge.
Now, and without altering the orientation, place it back in the slot lining up the slot to the peg in the receiver. Now with a little pressure you can clip the memory module back in the slot and the tags will pop back into the locked position.
Okay you have done it, its as easy as that. So when the new stuff arrives you will know how to fit the new modules.
Your new modules could have twice the value of the old ones, so if your board can handle say 1 GIG of memory in two slots, thats a max of 512 megs in each, you might have 2 x 256 megs fitted and there are no empty slots, so pop out the 2 x 256 and drop in the 2 x 512 making an upgrade of ½ a Gig (in each slot) giving a total of 1 Gig.
The probability is that there are four slots, two of which might be empty, its the combination making up the total that determines how much extra you can fit....
I hope thats clear??
BluRay
Nov 22, 2008 | Asrock K7VT4A+ Motherboard
Cannot play games
One gig of ram is still very low for major gaming. For good gaming, you should have no less than two and preferred, you should have four or more. The card is ok as long as it is 256 megs of dedicated not shared memory.
Nov 12, 2008 | Asrock 775VM800 Motherboard
Patriot laptop manual
Go to the below link and download the manual.
"http://www.user-guides.co.uk/Patriot/PatriotCDDownloads.asp"
Thank you..
Sep 09, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
