Question about Sharp EL-531VB Calculator
0.0000000000 is stuck on my calculator - Sharp EL-531VB Calculator
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out.
or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out.
probably it willcome with anything that is stuck beneath the printer
M.P
Sep 11, 2014 | Sharp EL-1801P Calculator
Unlock code for lg bh100
If your dvd is not multiregion you will need to hack the system to get it unlocked
Apr 22, 2008 | Televison & Video
My TEXAS Instruments TI-83 plus just stuck , and whatever I push any bottoms. I try to take battery off and open it again and it still stuck .
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we can go from there.
Dec 31, 2010 | Texas Instruments TI-83 Plus Calculator
My kids got a hold of my calculator. Now it won't
Apparently it's stuck in Exact mode. Press MODE then F2, move down to "Exact/Approx", press right-arrow, and choose the desired mode.
FYI: even when you get a fraction, you can convert it to decimal by pressing Diamond followed by ENTER.
Apr 30, 2010 | Texas Instruments TI-89 Calculator
Monroe 7130 displays an "E" and I won't respond.
Even you turn off then turn on the calculator, the 'E' still there? As I know, when 'E' display, if any key is stuck (press the key and it never pop up), all other entries will be ignore, until u release the key stuck. And, please confirm the printer is not stuck.
Jul 13, 2009 | Monroe 7130 Calculator
Screen shows an arrow and a zero ---and is stuck there. Tanx
see do some button has been stuck inside the calculator if it is stuck you should take it out by move in it because if some button is pressed you cannot push no other buttons
Jul 11, 2009 | Sharp Office Equipment & Supplies
The calculator stucks
remove the battery from it
then reinsert the battery again then try reset button it wit be perfect
Mar 07, 2009 | Sharp EL-531VB Calculator
Ti-83 plus is frozen in the middle of a calculation.
This just happened to me. Running my fingers over helped because the problem was caused by a 'stuck' key. Sometimes it is clearly stuck to down but othertimes it is pretty hard to tell. Regardless when a key is pressed you can't press any of the others until it becomes unpressed.....so one thing to try is to hit the back of the calculator until the keys are all unstuck.
Mar 06, 2009 | Texas Instruments TI-83 Plus Calculator
WHAT IS SMS AND WHY CANT I REPLY TO THE MESSAGES
SMS is Short Message Service. This is coming from a email address. you can send your self one to. 0000000000@page.nextel.com to send a normal Test alert via email send it to 0000000000@messaging.nextel.net were you see the 0000000000 put your Nextel number.
Apr 15, 2008 | Motorola Mobility i880 Cellular Phone
Sharp EL-531VB Calculator Logo
143 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
