Question about Behringer XENYX 2442FX Mixer
There is no power . It will not turn on. Iv'e checked the fuse. It is fine. No power.
  • Behringer Master
  • 5,603 Answers
Try a different cord on the slight chance the cord could be defective.
If that doesn't work, take it in for repair.
Posted on Sep 08, 2010
How to reset amp to factory setting....120w spider iv
Press and hold the 'A' or 'Clean' button in while turning on the amp's power. Hold for 5-8 seconds.
Jan 31, 2015 | AMP Music
No power in Mackie TH-15A
i) I assume the fuse you mentioned was in the mains plug - did you also check the fuse in the TH15A mains input socket? This is accessed by pulling out the tab in the bottom section of the socket (below the centre pin). This is a 3.15Amp antisurge fuse, 20mm type.
ii) If this fuse has blown, then replace it & all may be well ...... but if it blows again, then move to step iii).
iii) With mains disconnected, remove rear panel (outer screws) & check the power supply PCB for damaged components, especially R111 & R112 (100ohms). If the latter are burnt or open circuited, then the amplifier module may have blown.
regards, Dave
Aug 20, 2014 | Mackie TH-15A Active DJ Powered THUMP...
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
New subwoofer blows fuses
you have some wires touching causing it to ground.check wiring
Dec 27, 2012 | Gemini Sound Products Gemini GVX SUB15P...
It wont turn on and starty working iv changed the batterys what else can i do ?
Check battery direction. Also if the unit can use a power adapter, sometimes the contact in the connector for the adapter that connects the battery when the adapter plug is out fails to contact and connect the battery.
Jan 30, 2011 | Disney Hannah Montana Karaoke System with...
I purchased a Passport 500 less than one year ago, used it maybe 10 times and recently turned it on to use and it would not power up. No lights nothing. Checked the fuse ok. Tried a new fuse nothing. ...
Check that the power cord is seated completely. These are hard to work on and if there is a failure in it, it is unlikely you will get it restored in time. I would suggest renting a system until you get it repaired. You need rent only a powered mixer with suitable cables as your speakers should be fine. The way the Fender Passport is packaged makes them difficult to work on.
Jan 11, 2011 | Fender Passport Deluxe 500watt Sound...
My bass amp Behringer bx 4500 dont have power when I turn on the switch. I check the fuse but it was fine. What could be the problem of the amp when it does not turn on?
First thing is to verify that the power cord is GOOD and that it is fully seated. Beyond that repair is NOT DIY. Take it to a repair shop.
Jan 09, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Behringer XENYX 2442FX Mixer Logo
46 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
