Question about Whirlpool Accuwave Microwave Oven
What is the F7 code mean? - Whirlpool Accuwave Microwave Oven
  • Whirlpool Master
  • 9,098 Answers
According to the technical sheet found hidden inside the unit behind the controller and online here:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem. (Possible reason: Over temperature protection for the magnetron opened.)
3. Check resistance of the magnetron thermostat. It should be close to 0 ohms.
4. Check the magnetron.
5. Check wiring to the 1100W inverter and control system.
6. Check operation of all interlock switches.
7. If switches operate correctly:
- Replace 1100W inverter.
- If problem persists, replace power supply board.
8. Plug in microwave oven or reconnect power.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Sep 08, 2010
  • magataganm Feb 25, 2011
    Whirlpool lists 2 inverters for this unit. Neither is listed as 100W. Can you explain which inverter is the 1100W?
2 Suggested Answers
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 01, 2011 | Whirlpool GH6177XPS Microwave Oven
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
Its got a code coming up saying f7
Most F7 codes are saying the keypad is sticking. Try running your fingers flat up and down across the keypad then horizontally multiple times and see if the F7 code clears. You cna verify this if you unplug the unit and then plug it back in. There should be a pause of about 16 seconds then the F7 code will appear if it is in fact a keypad problem.
Jan 22, 2010 | Whirlpool GH7208XR Convection / Microwave...
F7 Error code on Kenmore Ultra Wave Microwave Hood Combination Model 665.61652100
The 665 the model number prefix means it's made by Whirlpool. F7 means it has a problem with the control board or keypad.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it still has a problem, we repair these for customers nationwide with our guaranteed $39.95 service. If a new keypad were needed, that would add about $60 to the repair cost.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 03, 2008 | Kenmore Microwave Ovens
Error Code
F7 problems are usually caused by poor connections. I suggest to unplug the ribbon connector off the control board and cleaned the copper connectors using alcohol or with a pencil eraser. If that does not work the touch pad may be defective.
Jan 19, 2008 | KitchenAid KHHS179L Convection/Microwave...
Microwave Ovens Logo
733 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
