Question about Ruud UBHC Air Conditioner
My apartment has a Ruud UAND-024-JAZ installed since 2006. It takes approximately 7 hours for it to reach the temperature the thermostat is set to (77) My landlord had a service personcome out and flush the coils 2 months ago, the unit was checked and the vents have been cleaned. He said the unit was fine. My electric bill is running about $100 a month..which I think is high. I wonder if there is something else that was overlooked.. Regards, Linda
  • 43,501 Answers
With out knowing where exactly you are and how many sq. ft. you are cooling it is impossible to tell if you are working properly or not...
The best way to tell would be for you to check the return air temperature and the supply air temperature. There should be at least a fifteen degree F difference.... if not then you have a problem...
Heatman101
Posted on Sep 08, 2010
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Dado
Sep 07, 2014 | Electrolux Freezers
Ruud achiever photos Jakob 042-jaz
thermostat, outside unit bad contactor. inside unit fan relay.
Jun 04, 2014 | Ruud UAKA042 Air Conditioner
Caravan does't reach operating temperature
No one ever said new means good. Try another thermostat. Make sure it is the recommended temp for the vehicle. I would spend the extra money to buy a dealer thermostat. What controls temp is restriction of flow thru the system until a set temperature is reached and the thermostat opens. Has to be a thermostat.
Dec 31, 2013 | Dodge Caravan Cars & Trucks
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
My coils on my ruud uand -030-jaz unit are jammed with yard debris..a technician said 110.00 for an acid cleaning solution would take care of the problem and he said the contacts were corroded what can i...
Hi, clean the coil with your garden hose and spray nozzle, but be careful not to bend the aluminum fins. I have never had to use the acid coil cleaner, all it does is make it shine!! I have cleaned coils all of my life to lower the head pressure, just spend some time doing it. Make sure you get most all of the debri's. He must be talking about the contactor contacts being corroded. Kill the power, and use a piece of sanding cloth to clean them up. You can do all of this your self.
Sincerely,
Shastalaker7
A/C, Heating, Contractor
Aug 04, 2010 | Ruud UAMB Air Conditioner
3 year old a/c unit will not run outside is there a reset button?
Make sure that the breaker for the A/C is turned on, there should be a disconnect mounted on the wall, near the A/C unit outside. Ishould have a breaker or a set of fuses, the fuses will need to be ohmed out, as you cannot tell if they are bad just by looking at them.
Where the 2 copper lines connect to the A/C unit outside, there is a red reset button, push it in and make sure that it is not tripped.
I hope this gets you started in the right direction.
Have a great Day.
Paul
Apr 06, 2010 | Ruud UBHC Air Conditioner
RUUD M/N UAND-024JAZ;heat operation issue
Its a wiring problem.
w = white
r = red
y = yellow
g = green
c = brown or blue
check how the furnace is wired, it should match the new thermostat you installed.
www.fastacservice.com
Oct 18, 2009 | Ruud Heating & Cooling
RUUD (Protech Model 500) Thermostat Single Stage Not Programable
problem is not the thermostat, thermostat is an on-off switch that happens to work on temperature. Your furnace is locking out. cycling the heat off switch resets the micro-processor in the furnace. You need to diagnose the problem in the furnace, to go further we will need the model and approximate age of the unit
Dec 11, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
123 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
