Question about Whirlpool WED5300S Electric Dryer
I have a Whirlpool model WED5300VW0, electric dryer. It's only 1 1/2 years old. The other night, I had a load of laundry going, and discovered it was still running after almost 3 hours. The laundry was completely dry (and hot). I had set the dial to a little more than 'Energy Preferred' on the Accudry cycle. The dial seemed to have moved down to the 'Energy Preferred' level, and stayed there (as opposed to moving further down to 'Cool Down' and then off). The next day, I decided to try it again on the 'Timed Drying' cycle. I set it for 20 mins. The dial did move, but after about 1 hour, it was still running (and the dial was on 'Cool Down'). I checked the link trap, and the vent pipe, and everything was clear. I ran it again on 'Timed Drying' with the vent pipe disconnected, just to make sure, and same thing - it just kept running. Any ideas? Does it sound like the Timer unit is bad? Is there another way to test it? Is it easy to replace? Thanks very much for any advice.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, the timer is bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Testimonial: "Thanks heatman101. I replaced the timer, and that seemed to fix the problem. The dryer is working again."
My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
My 4 1/2 year old electric Whirlpool dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Moisture sensor not working
Once I discovered that the problem was not the dryer, I went into my crawl space and discovered the plastic duct was clogged with lint. Apparently the duct was not changed since the house was built over five years ago! The 4" duct was also duct taped to a 3" connector. Additionally the line ran into the crawl space at a 90 degree angle in a space that was only 2" wide! My husband adjusted the way the line ran into the crawl space and replaced it with a rigid aluminum duct. The auto sense works on my dryer and it takes only 30 min. to dry a load of laundry instead of 1-1/2 hours!
Dec 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Jul 25, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Whirlpool WED5300S Electric Dryer Logo
709 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
