Question about Hotpoint Refrigerators
Have a hotpoint refrig model HTS18GBARCC-the small motor/fan assembly at the back of the freezer makes a squeaky sound as it rotates. A SLIGHT TOUCH WITH A PENCIL SEEMS TO PUT IT BACK ON TRACK FOR A LITTLE WHILE BEFORE IT DOES IT AGAIN! wHAT DO i DO?
  • 4,070 Answers
It is going bad and needs to be replaced. Here's a diagram and parts list of your model. Part 650 is the fan motor. http://www.partselect.com/ModelFrames.aspx?ModelID=360117&ModelNum=HTS18GBMARCC&mfgModelNum=&ManufactureID=2&Selected=00107990i07&Position=7&mfg=GE&Type=&Mark=7
Posted on Sep 08, 2010
When freezer fan comes on it does not sound great, sounds like it is ready to go out how can i check it? HOTPOINT SIDE/SIDE HSS25GFTAWW
if you can access the blade on this fan carefully touch the rotating blade and see if it is difficult to stop the blades,if it stops relatively easy then the motor is going bad
Aug 30, 2012 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
Freezer is cooling, but refrigator is not cooling
take a look at your evaporator fan motor in the freezer to make sure it is running and not built up with ice around it. this fan motor pushes the cold air from the freezer into the fridge to cool the fridge. you say the freezer is "cooling" , is it freezing??
Oct 14, 2009 | Hotpoint Refrigerators
Bottom cools and top cools but dose not freeze . Do not heart fan when frezzer is opened.
you do not hear the fan ? your evaporator fan is not working - shut off everything and remove freezer panel look for any excess ice or frust blocking the fan - if everything is clear try spinning the fan blades with your hands, is there any resistence or it spins freely ? Put back cover and turn it on - if fan fails to spin then you have to get it serviced and change the evap fan motor assembly or check the control board.
your unit won't cool if the fan is not working or working erratically.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
HSS25GFPA WW HOTPOINT REFRIG.
Please don't rate this solution because people generally don't rate well when it's bad news, even though the response is correct. When the DC evap. motor goes out, it can take out the motherboard. (located behind the small panel on back of the refrig.)
Oct 22, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Freezer fan stopped working
Sounds like you need a new fan motor. First make sure the fan blade turns freely and see if you can move the shaft side to side, or up and down. If you can feel any movement in the fan shaft the bearings of the motor are bad. It is possible for some ice to have the fan blade frozen causing the motor to stall. Some models also have a fan light switch install at a point near the hinge side of the door.
May 02, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
My 16-year old refrig makes a single knocking noise when it starts to cool. It sometimes makes that noise if it's just sitting there. Just replaced the fan assembly behind the freezer wall. It wasn't...
Just a thought..fan motors usually have some front to back play (looseness). When the fan first turns on ..it may make contact with something, however after a few blade revolutions, the air pressure will push the fan one way, and allow it to be quieter. If not the fan, the compressor will also have some starting torque possibly causing a knock.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
