Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
We have had ou dishwasher for about two years and it never has dried the dishes. We had a serviceman out and he said that it was some kind of new government regulation that the could only heat them so hot. But I am talking about the dishes being wet and not hot.
  • Frigidaire Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
Does not dry the dishes
CHECK THAT THE WATER IS AROUND 140 DEGREES, THE DISHES WILL DRY THEMSELVES IF THE WATER IS HOT ENOUGH. TO RELIABLY CLEAN DISHES THE TEMP SHOULD BE APPROX. 140 DEGREES.
Mar 10, 2010 | Whirlpool Dishwashers
How do I get the Electrolux dishwasher to dry the dishes?
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Jan 07, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Does Not Dry Dishes
Withe the model and serial number it appears that this dishwasher is less than 2 years old.
Your symptoms point to a failed heating element. That is kind of surprising because this dishwasher ~should~ report an error code if the thermistor does not detect the raising temperature from the heating element.
The LG LDS and LDF models do NOT turn on the heating element in the drying cycle. It turns it on during the final rinse and the dishes dry as the built in fan runs.
So, I suspect the drying fan and related gear is inside the door panel. Do a load of dishes and listen for the final rinse to drain. Then, listen really closely near the top of the door for the quiet sound of a fan _and_ place your hand underneath the left hand side of the closed door for warm air blowing straight down.
If you do not hear./feel what I discribed , the drying system has failed. OH, and if you have any water leaking from the door (right where the warm air is supposed to come out, contact LG service folks and firmly request that they replace the drying parts with a retrofit kit.
Please review this and tell me what works and what questions you still have.
Good Luck and please keep me posted! OK?
Mar 24, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Maytag Quiet Series 300 Not drying dishes at all
Hi brookeroy
I'm Harvey the Master Plumber.
Your question is your Maytag is less than a year old in a new home. Your folks have a dishwasher either the same or similar and it dries the dishes and doesn't leave water on them. Our dishwasher leaves water on it like the dishwashers from when I was a kid. Lots of water and spots and have to basically prewash all my dishes. It there something I can do or should I try to find all the paperwork?
First try 'jetdry'. Then call for warranty repair. Your d/w should still be under warranty.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Not Drying the dishes
How new??? If less then 1 year Call Warranty, you paid for it.If not I will be here to help you through this .Please rate this !!!!
Aug 08, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Turning on dishwasher
although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Jun 14, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
113 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
