Question about GE Microwave Ovens
Three buttons in lower right hand side are missing: Vent, Boost, Light Can I get replacement buttons? You can turn on light/vent by pressing pencil or sharp object in the button hole.
  • GE Master
  • 9,047 Answers
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Sep 08, 2010
I have a GE Space maker 2.0 model JVM2070SK02 that has three buttons on the lower right vent, boost and light. The light button is pushed up into the microwave. I think there must be a spring behind the...
Remove the top grill and on top of the control panel is (1) screw, remove that and gently tap up the control panel to release the panel from the microwave front cabinet. Now as I researched this model, the buttons are part of the panel and are attached to the panel directly. Up may want to replace the microwave as the price is high to replace the panel. Part number is WB07X10972, Good Luck and be safe and unplug this unit before removing this panel.
Nov 16, 2014 | Microwave Ovens
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
Vent, Boost, Light buttons pushed in - not working
They may be available as a unit--two or more and will either be melted into place or secured with screws etc.
May not be a easy part to find or see if it is even sold as a part.
Dec 12, 2012 | GE Microwave Ovens
How do you change the light bulb on an electrolux built in microwave ?
It is indeed straightforward but it requires removing the 4 phillips head screws that hold the trim kit on. Then you need to remove it from the cabinet (along with unplugging the cord.) Once that is done you will need to remove the 4 black phillips head screws along the bottom part of each side, 2 phillips from the left rear and 2 security T20 screws from the right side. I found that removing the 2 screws holding the bracket on the capacitor and the front allowed me to move the light housing enough to get to the bulb. In my case the bulb had unscrewed itself. I am not a big fan of the engineering associated with this model or the labor that assembled it.
Oct 23, 2010 | Electrolux Over-the-Range Microwave
I am realtor. Just sold home with built-in over the range GE Spacemaker 2.0 microwave oven (JVM 2070). The three buttons on lower right hand side (vent, boost, light) are missing. You have to stick...
Yes. You can find handy exploded views and order parts by model number here.
To aid in disassembly, the service manual is HTML clipboard here.
Sep 07, 2010 | GE Profile Spacemaker Over-the-Range...
Problem with light,vent, and the boost
Depends on the model #. I dont see it on here. This unit may have some kind of button assy that has broken and fell back into control panel.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Aug 08, 2007 | GE JVM3670 Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
