Question about Dishwashers
Circulation pump frozen - Dishwashers
  • 901 Answers
If you are sure remove it and clean.
Posted on Sep 08, 2010
My car will start and run for a day then it want start can you start it if the water is frozen in it
Friend,
You have a problem.
Engines are not designed to be frozen.
Engine coolant should be a 50:50 mix of coolant (anti-freeze) and water.
Straight water in an engine will freeze if the temperature gets low enough.
Water when it freezes expands with incredible force, so when trapped in any confined space, it will break the material trapping it.
That means that frost plugs will pop, blocks will crack, the radiator and heater core will burst, and water pump impellors will be locked in place.
If you try to start a frozen engine you may break the serpentine or fan belt or the water pump.
If it should start, there will be no coolant circulating so it will critically overheat in a very short time.
Friend,
You have a problem.
Best of luck.
Dec 08, 2015 | Refrigerators
Asko d1996 circulating pump
A new circulating pump will be available on line from this site
Asko Dishwasher Circulation Pump 8801312
Aug 29, 2014 | Washing Machines
What would cause a circulator failure?
I am going to assume the circulator pump is on a hot water circulation loop. Turning the water back on could have stirred up the sediment that has collected in the bottom of the water heater. This could clog up and possibly ruin the impeller. Running for an extended period without circulating water can overheat and damage the pump also. It is a good idea to hook a hose to the water heater drain and flush out the sediment periodically. Hope this helps.
Jan 18, 2014 | Bell & Gossett 103252LF NBF-22 Circulator...
Need help in getting Honda engine on NorthStar pressure washer to run.
Could be low water pressure I have found.
Also, I purchased a can of "stuff" at Lowes today which allows you to circulate a liquid substance which lubricates the pressure pump....the pump could be frozen up...
I have a rotating nozzle which I bought...and it had frozen up...this stuff works
Aug 31, 2012 | Northstar Pressure Washer 3000 PSI
Need to trouble shoot circulator pump. Aquastat has power but need to figure out what is preventing circulator pump from kicking on.
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
Dec 11, 2010 | Honeywell HE360A1027 Whole House...
What would cause it to run hot and the heat stop working at the same time?
I've seen cars run hot and the heater not work for the following reasons:
1. The radiator is frozen solid and the coolant can't circulate.
*** The fix, get the car into a warm garage and let the ice in the radiator melt. Once done, add the correct mix of antifreeze so it doesn't happen again.
2. The water pump is not working and the coolant isn't circulating.
*** The fix, replace the water pump and adjust antifreeze mix.
Dec 06, 2010 | 1998 Chevrolet Tahoe
Frigidare dishwasher doesn't run
If you have your dishwasher on an outside wall, the water line may be frozen, try opening the sink cabinet doors allowing warm air to circulate around the water line.
Jan 17, 2009 | Frigidaire Dishwashers
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
Owen Barnes
