Question about HP Pavilion dv5-1000us Notebook PC
I have light where power cord plugs in but nothing else. I do not have a screen or any kind of power unless i hold the on button down and the lights will flash just under the screen, but nothing else
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
HP 1315 printer won't turn on
I have an HP printer too, but it's HP 2050. When i plug it in it usually makes a noise and then the power button blinks. To turn it on requires me to hold the power button down for a few seconds until the power button light stays on. If you haven't tried yet, try pushing down and hold and see if it turns on. Hope this helps :)
Apr 20, 2014 | HP Photosmart 8450 InkJet Printer
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
While installing the HP Photosmart Full Feature Software and Drivers from the HP website, power went out for a few seconds. When power returned the printer was off and will not turn on when the power...
Theres nothing in the drivers that would cause this unless the software was doing an update to the printers internal software
you could try a hard reset
1. Remove all cables, including:
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in. .
Mar 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hi I closed my laptop to put into hibernation mode and then noticed 2 days later that the power light was stuck on and not in hibernation. Upon opening the screen back up nothing happened. No lights, no...
You can try this: Shut the computer down and unplug the power cord from the computer. Remove the battery, then push and hold the power button and sing happy birthday to it. Or wait 15 seconds. Then plug the power cord back and try turning the system on. After it boots up, providing this fixes the problem, you may then replace the battery.
Hope this helps!
Feb 16, 2011 | Dell Studio 1737 Laptop
The laptop was turned off improperly and the power light is on but there is nothing oon the screen
Try pressing and holding the power button down until the power light goes off.
Once it is off, then try to turn-on the laptop as usual.
If this does not work, remove the power cord and the battery from the laptop, and then press and hold the power button down for 30 seconds.
After the 30 seconds, release the button, install the battery and re-connect the power cord. Start the laptop as usual by pressing the power button briefly.
Dec 29, 2010 | Computers & Internet
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
DELL Latitude D505
Have you tried the other fix? It often times works.
Remove the battery AND the power cord.
Hold the power button for 10 seconds.
Now plug in the power cord.
Magic should happen
Feb 27, 2009 | Dell Latitude D505 Notebook
HP Pavilion dv5-1000us Notebook PC Logo
64 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
