Question about Dryers
My maytag mde8416ayw dryer does not start. There is power, because the light bulb comes on. I have checked the wiring on the control panel to the best of my ability, but have not removed the large metal casing to reveal any of the dryer motor or insides. What should I do?
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 08, 2010
How do I remove the light wiring harness from the front panel?
Type Maytag Epic Z into YouTube and see if the video comes up, thanks!
Jun 25, 2015 | Maytag Epic z Front Load Gas Dryer
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
HOW DO I FIX MY MAYTAG DRYER. IT DOES NOT START WHEN I PUSH
There are a few things that come to mind why your dryer may not start: -Check to make sure there is power going to the dryer -Check that the door switch is working -The motor may have overheated -There may be an electrical fault or loose wire -If the motor turns but the drum doesn't, check that the belt is still on the drum.
For some of these checks you may have to remove the control panel or the front panel. Depending on your skills and experience you may want to have some of these checks done by a qualified professional due to the danger of live electricity.
Jul 29, 2011 | Maytag Dryers
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
The Dryer stop working. The Start button doesn't
You need to check to see it you have power coming out of the timer? There should be a wiring diagram inside the control panel.
Door switch should be checked with the timer set to run and start switch pressed down to start. Check for power at the motor see wiring diagram for which terminals.
If you give me the model # so I can look it up I can try to walk you through it.
Mar 22, 2010 | Maytag Dryers
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
