Question about Kicker KX1200.1 Car Audio Amplifier
I have a KX1200.1 amplifier hooked up to a kicker 12in SoloX. Everything was working. I had an accident to the rear of my car, the amp was knocked off the mount to the back seat. But even after it was reinstalled it was working up until a month or so after. Now the amplifier isn't working, green lights on but no red light. I took my car over to best buy to have looked at, nothing wrong with the sub. Its gotta be the Amp but what? I believe the techy said the amp was on but that it wasn't putting anything out.I have a sneaking suspicion it has something to do with the surge protector. I'm dealing with insurance over this, they're trying to contest it wasn't from the accident. They want proof. I have an another appointment with best buy on saturday to open r' up. But i would love to hear ideas on what I might be looking for to prove it was part of the accident? What might pop out when the Amp is opened up? What parts would prove it?
    Sergeant:
    Habit-Forming:
  • 148 Answers
Its most likely a dry joint. Some components have loosened other wise i doubt there could be a major damage to the amp.
Posted on Mar 10, 2017
simplemitch
  • 752 Answers
SOURCE: Red light is lit on my Kicker KX400.1
the water shorted it out. It will need to be repaired.
Posted on Sep 15, 2007
zzedly
  • 300 Answers
SOURCE: green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Posted on Mar 16, 2009
  • 14 Answers
SOURCE: i think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Posted on May 01, 2009
djmaximus_87
  • 26 Answers
SOURCE: i just got a kicker 1000.1 amp. i hooked
HI DUDE .. MOST OF IT COZ UR POWER DIRECT TO UR BATTERY ..
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: Kicker 750.1 Amp wont play music
The wire you are needing to check is the Blue antenna wire that runs from the back of your deck to the amp. More than likely if you are getting a green light on the amp than that means this wire blew a fuse somewhere or blew the amp itself. I would say re-check all the fuses. (there should be one in front of battery wire and some on the amp) If these are still good and you are still getting green light but no sub than check the wiring for the box. I just had to re-wire my box because one of the cables came loose in the box. I have a Kicker 750.1 and a kicker 12" L7 so i understand what you mean... it just takes time and understanding. If everything fails and still it wont work.. than hook the amp up to a friends car and see the results.
Posted on Sep 09, 2010
How to wire kicker 07cvr124 4ohm duel voicecoil 12in sub to my rockford fosgate 4channel punch 600r amplifyer
run the positive from one voice coil the the negative on th other than take th left over positive from one voice coil and the negative from the other and bridge it to the amp use the blue sub wire but u will have to buy a 1 unto to splitter to hook up ur rcas from amp
Mar 28, 2012 | Rockford Fosgate Car Audio & Video
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
I cant remember how to install the kicker 12 l7
Your subwoofer is single or dual voicecoil? And what amplifier Make/model are you putting it on?
Thanks!
Nov 04, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Amp is a mtx 801d not sure
no you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
Oct 05, 2008 | MTX Thunder TA7801 Car Audio Amplifier
System not playing
Sounds like the output transistors on the amp are blown. Were you slammin when it stopped or how did you find out it stopped working. It could be the sub failed then caused the ap to go which is why you get a little something from the JL.
Feb 11, 2008 | Car Audio & Video
IX704
you need an ignition noise filter available at radio shack. This electrical filter blocks "engine noise" to reaching your audio amp.
Jun 11, 2007 | Kicker IX704 Car Audio Amplifier
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Kicker KX1200.1 Car Audio Amplifier Logo
42 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
