Question about Tiger JAE-A10U 5..5-Cup Rice Cooker
Can I replace the lithium battery in my Tiger rice cooker?
  • 48 Answers
SOURCE: toggle lever will not stay on "rick cooking" option
well your rice cooker needs to be replaced.. if you still want to use it, then have it fixed by a technician coz it needs electrical expertise to handle the wirings inside it..
Posted on Jan 23, 2008
jdrrwoods
  • 82 Answers
SOURCE: zokirushi NS RNC10 Rice cooker warmer
http://www.zojirushi.com/ourproducts/ricecookers/ns_rnc.html
go to this link they should have a way to order one here
Posted on Feb 07, 2008
dutchman05
  • 487 Answers
SOURCE: farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Posted on Jun 24, 2008
SOURCE: Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker
After extensive web search, this seems to be the only Website listing Panasonic parts:
http://www.partstore.com
Posted on Oct 25, 2008
  • 54 Answers
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
Posted on Jan 11, 2009
Where is the battery of Tiger rice cooker?
Support Try here and put in model number for rice cooker
Mar 10, 2017 | Tiger Kitchen Appliances - Others
How to replace the lithium battery ?
I have read that it is soldered in place. If you are good with electronics, open it up and look for the battery? I do not know what kind of battery, you will have to look and try to find a correct replacement. If you are not good with electronics, find a friend who is, or pay someone who can fix phones and electrical clocks.
Aug 01, 2014 | Tiger Corporation Tiger Jay-a55u Rice...
I want to purchase the inner pot model AYA55U of the Tiger Rice Cooker model No. JAY-A55S, may I know where I can buy it.
I saw that the Tiger website had pots for sale but you had to call them or something. Try their website on how to contact them
Sep 28, 2012 | Tiger Kitchen Appliances - Others
Tiger jag-s wont start
I have a Tiger jag-s and it had the same problem and I fixed it just by replacing the lithium battery. It's little bit tricky though to replace the battery. You can take the bottom cover off by removing the 4 screws (this part is fairly straightforward). Once you take off the bottom cover, you'd see a circuit board at the front side (it's vertically installed). You'll see the lithium battery on the circuit board. But the lithium battery is sort of soldered on, as others already pointed out. Now is the tricky part. To take the battery off, you better take the circuit board out first. To do so, you need to disconnect the wires and take the three screws out. But before you unplug the wires (that's easy), you SHOULD take a nice photo first so you'll be able to replug them correctly afterwards. Check your photo to make sure you'll be able to recognize all the wires and clearly see how they are plugged before you take action. Once you take the circuit board out, you need just figure out how to get the battery off. I found it's really not soldered on because I couldn't get it off by heating it with a solder gun. So at the end, I just used a box cutter to pry the two wire plates off the battery. Do whatever you can, but just be careful not to break the plates. Once the battery's off, I just used tapes to fix the new battery on (make sure the battery's in the right direction). Once the battery's replaced, the cooker works fine as before.
Sep 18, 2012 | Tiger Corporation JAGS10U 5.5-Cup Rice...
How to replace lithium battery on Zojirushi NS-KCC05
how can i change the battery on my ZOJIRUSHI rice cooker
Aug 13, 2012 | Zojirushi NS-KCC05 Micom 3-Cup Rice Cooker
Replace battery in Rice cooker - Tiger TAE-A10U
Hi wlegray...
Found this information on the Tiger website...
"To prolong the internal battery life keep the unit plugged in.
Keep in mind that the cooker will still perform properly without the battery as it just runs the clock when the unit is unplugged. Life of battery is approx. 4 yrs."
As long as power cord is plugged into power source, you may able to use all the features.
If you like to replace the battery, contact customer service.
A fee may apply.
Please take time to rate me
Tiger Home website... http://www.usa.tiger-corporation.com/
Customer service...https://www.usa.tiger-corporation.com/contact/
Sep 18, 2011 | Vacuums
Where is the lithium battery located on a JAE-A18U model?
Removed 4 screws with black plastic on the bottome. Then slowly seperate the lower housing. Lithium battery is located on the electirc diplay unit which has 3 screws. Unfortunately, the battery is soldered on and will require a shop with soldering experience to replace. I'm having the flashing 0:00 issue and my rice cooker is not working.
Sep 14, 2011 | Tiger JAE-A18U 10-Cup Rice Cooker
Tiger rice cooker
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jun 25, 2009 | Tiger Corporation JAGS18U 10-Cup Rice...
Toggle lever will not stay on "rick cooking" option
Nov 30, 2007 | Tiger JNP-0550 3-Cup Rice Cooker
Tiger JAE-A10U 5..5-Cup Rice Cooker Logo
631 people viewed this question
Top Tiger Kitchen Appliances - Others Experts
Irene Tulloch
ray gallant
Bill Boyd
Are you a Tiger Kitchen Appliances - Other Expert? Answer questions, earn points and help others
