CD tray not opening on Denon RCD-M35DAB
Denon have talked me through various button combinations to try and resolve this without success.
Anybody got any ideas on what the problem might be?
  • deadeasy Sep 19, 2008
    The CD tray won't open on my Denon, and there doesn't appear to be a button on the remote. I've tried various combinations of turning off and on, and pressing buttons in different but can't get it to respond. It seems to me that it's a software problem. I have another Denon (MD35) and the volume control on the actual device doesn't work. As soon as you twist it, the volume shoots up to . The only way I can change volume is via the remote.
There are tthere are two transparent plastic switches under the tray
there (a gray plastic piece, intcasing the loading motor is nonot rotated enough, not allowing the necessry pressure on the switch.
you must in either case disassemble the reading module comprising the tray, otics annd spindle, so you gain access to the underside of it, from ence coperatrepositioning the tray or the lrotating the trigger\eloading motor.
Posted on Aug 03, 2009
  • larraz Aug 03, 2009
    sorry for the typos...i wasn't actually seeing while typing.
    again: there are two switches under the tray- on the right sits the opening switch - if the unit endured a fall or similar, the tray may be tooo upfront.
    on the left, the closing switch, wich also commands the positioning of the reading spindle and optics-again in case the unit fell (or caused by usage and wear) the position of the trigger that activates the switch is wrong, ussually too far to make contact. this trigger is easily identified,consisting of a gray plastic extension atop the loading motor, connected to a a gear system, and through it, to the tray.
    you symply have to rotate it to the correct position, though it may be tricky to syncronize it to the spindle motor. try and error mo.
    in either case, you must gain access to the underside of the tray, wich requires you to disassemble it.
    hope this helps, worked fine with me, after a few hours fiddling with the apparatus.
Denon user manual model RCD-39
Try Googling (denon)(RCD-39)(manual) without parens.
Aug 28, 2017 | Denon Audio Players & Recorders
My denon rcd-m35dab, there is disc in and plays ok but cannot open the drawer it just shuts down/turns itself off
Check the belt or drive that is responsible for opening up the disk tray. If it is slipping the disk will not come out.
Mar 07, 2015 | Denon Audio Players & Recorders
Denon not switching on
Talk to Richer Sounds hi fi there will be a shop near you if you are in the UK.
Jul 22, 2014 | Denon Audio Players & Recorders
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
Cd ejection tray
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
Jul 25, 2010 | Denon D-M33 Shelf System
Hi there . i have a cd reciver denon rcd-m33 which wont open and close the cd tray it just says demo mode when the button is pressed. please any help .....
Hold the function button in while it says CD.
Turn the machine off then on.
Try to eject now.
Worked for me.
This was achieved accidentally so if it doesn't work first time, try various combinations using these two buttons.
Jun 20, 2008 | Audio Players & Recorders
Audio Out from Samsung LE40F86BD
check your samsung owners manual for audio settings to see if this model has a audio time delay setting .
Feb 26, 2008 | Hitachi 51F510 51" Rear Projection...
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
549 people viewed this question
 Grubhead
Grubhead
