Konica 1112 service manual
I found your post about how to clear error code and maybe you know how could we make a service operation for our Konica 1112 ? The indicator with a man with wrench is lighted...
Dainius
shadowed@bk.ru
  • 3 more comments
  • Dainius Shadowed May 25, 2008
    I do not want just reset and make that code not appear. I want to make full service (clean the heating elements and other things iside), do everything that I can, not just reset.
  • Dainius Shadowed May 27, 2008
    The screen does not show any error code, just 01, as in normal operation. But LED indicators are showing something - blinking upper left (total - 4 indicators) picture shows something like 6 balls in the box and above the box arrow showing to the box. One LED constantly burning - with a man and a wrench by him, whitch I understand is service technician :D what does the other sign mean I do not know. The copies coming out smeared with toner, so it need cleaning somewhere inside, so also I could make that service to get rid of that service technician :D
  • brian c
    brian c May 11, 2010
    OK, the "6 balls in a box" means it wants you to add toner. (i never heard it called '6 balls in a box' lol)
    If there is already toner in it, then you will need to clean out the recycle tube / cleaning unit. Neither can be done without a special vacuum without making a total mess.
    The smeared copies are most likely due to the cleaning unit being 'backed up'.
    That model was pretty notorious for the recycle unit drive gears cracking, thus causing the backup of toner - just a warning.
    The man with the wrench just means it has hit it's maintenance count. If it has stopped letting you make copies, it has reached its over limit count. It usually lets you make a specified number of copies after the light comes on.
    Sounds as though this machine needs a total maintenance (drum, drum blade, developer, fuser cleaning roller).
    You can check ebay, as parts for that machine are relatively inexpensive.
    I can assist you with manuals and instructions once you get the parts.
  • brian c
    Ok. I still need to know the error code so I can tell you what area needs attention.
  • brian c
    What is the exact error code that is flashing?
    There are different reset procedures for different codes.
I have a konica 1112 copier all of a sudden it gives me a black page no codes to read someone told me it is the cleaning blade is this hard to replace
Posted on Jan 26, 2009
The display flashing 26
Posted on Jun 26, 2010
  • 51 Answers
Sounds like the charge corona/roller is broken. Not charging drum
Posted on Apr 06, 2010
I have konica 1112 need to know how to clear code 25
Posted on Jul 06, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Hello my machine Bizhub 600 is indicating an error code C8101 when switching it on, who can i solve this
Actually C8101 is on Rank B meaning by Open / Close the front door to clear it.
But if error code still appear, Check the connector between M3-relay CN5-DFCB J15 for proper connection and correct as necessary.
Check the connector between PS12-DFCB J15 for proper connection and correct as necessary.
Check the connector of M3 for proper drive coupling,and correct as necessary.
PS12 I/O check, sensor check
M3 operation check (change M3)
DFCB F8 conduction check
Dec 08, 2014 | Konica Minolta bizhub Office Equipment &...
KONICA MINOLTA C253 COLOUR MACHINE ERROR CODE C-D403 touch screen not working printout not coming our service engineer could not find the error
The c-d403 code indicates a checksum error. Try turning the copier off and on via the Main power switch either behind the copier or inside the front door of the copier. Checksum error along with no operation panel means something could be fried on the main board.
Feb 17, 2011 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Err c 0500
This error code is a fuser problem and maybe in my experience a morning problem.
Try to clear the error the error with this procedure:
Hold down utility counter for 3 seconds and in the screen will appear a trouble reset, then touch it and turn off and on the main, it will clear the error code.
If it does not see if you have fuser problems with the termisotrs and also check the power.
Jul 21, 2010 | Konica Minolta Bizhub 222 Black and White...
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
Konica 1112 Copy Machine NEEDS TO LIVE a few more years
Call a service tech to come in and do a full optical cleaning. Requires removal of the glass.
Mar 04, 2008 | Computers & Internet
1,039 people viewed this question
jasbo
jasbo
