Question about Fuji FinePix A350 Digital Camera
Wont turn on
I have tried various kinds of batteries, checked polarity. Pls help.
    Brigadier General:
  • 3,614 Answers
Any indications on the battery when you try to charge it..
kindly send us some info regarding into this..
thank you
Posted on May 14, 2008
My relatives send me midland lxt320 i buy new batterys akari 1100 mah i turn on both units when i turn off both units now wont turn on agian pls help i try to clean all battery contacts thanks you
This appears to be some kind of radio controller, possibly for a model boat or aeroplane. You may get more help from a forum dealing with leisure equipment.
Nov 20, 2016 | Cameras
My daughter's brand new easy share camera will not turn on. When she plugged it in to recharge it, it got very hot but did not turn on. Nor when we changed the batteries. What can we do and where can we...
sir, did you try to cool down and reset your device. dont use it for a couple of minutes and remove the battery too. see what happens. i will look for another solution for this. hope that helps!
CHARCOIS
Sep 25, 2008 | Kodak Cameras
I NEED INFO FOR THE SUNPAK CL-3 NICD BATTERY CLUSTER FOR THE 622 SERIES:: HOW LONG DOES IT TAKE TO CHARGE: ARE THE BATTERIES REPLACABLE WITHOUT USING A TECHNICIAN:: HOW MANY FLASHES PER CHARGE:: AND
With a little care and some help from a knowledgeable battery supplier..., this can be done by an end-user.
-I am based in Vancouver B.C. and I deal with a company by the name of Polar Battery..., I did a google search for battery cell supplier in Vancouver BC and Polar Battery came up!!!
Note: try the using your particular city / region
-Polar was able to provide me with information as to various battery cel qualities and their prices.
Note: If your existing battery & charger is designed to use Ni-Cad..., stay with them..., likewise Ni-Mh or Li-Ion. This is because each style battery requires its own specific charging parameters. If you change the cells but not the charger..., you could cause yourself some real issues.
Hope this helps..., Peter
Oct 10, 2014 | Sunpak CL-3 NiCd Battery Cluster for 622...
My TI-83 calculator wont turn on when i pit in brand new batteries and it still wont turn on i have tried pressing every solution help please!!
I see thatt you do not have the same kind of batteries :for example, you need to buy alkaline from the same type all SONY etc do not mix other type or mark , not use differente mark. 2) must be sure about the polarities of the batteries 3) clean the contacts batteries for dust, oxide, corrosion 4) open the calculator for some wires desolder and resolder the 2 wires again.
If the problem persist you must go to the repair shop TV.
God Bless you
Nov 11, 2012 | Televison & Video
Just bought a ti 84 plus and it wont turn on pls help
Double check batteries and polarity first. If this doesn't help, return it to the store, you have a DOA (dead-on-arrival) machine. They're obligated to replace.
Mar 05, 2011 | Texas Instruments TI-84 Plus Calculator
Camera wont switch on
well assuming the camera hasn't been damaged, make sure of the polarity of the batteries when installing them. Also make sure they are all fresh and of the same kind. If one battery is bad, it will prevent the camera from turning on. If still a problem, use a "Q" tip dipped in alcohol to clean the battery contacts in the camera. If this doesn't solve your problem, contact the mfg about downloading new firmware for the camera... Hope this helps.
Jun 14, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
How to reprogram 1999 mercedes s320 key remote?
just insert the key to the ignition swich and leave it for one minute, it will work for sure.
Adel
Jan 15, 2009 | 1999 Mercedes-Benz S-Class
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
Still doesnt work
If you may pls:
  • post back make and model;
  • detail circumstances prior to the fuse blowing;
  • how many speakers are connected;
  • have you checked the speakers themselves;
  • is it a sub in bridge mode;
  • have you checked the polarity, possible wire short or grounded
  • do you have access to and familiar with a continuity tester (DVM)?
Aug 05, 2008 | Car Audio & Video
Fuji FinePix A350 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
