Question about Canon PIXMA MX310 All-In-One Printer
How to download faxes to my hard disk?
I would like to see and save to hard disk faxes stored in printer's memory before printing them. Is it posiible? And how?
  • Anonymous Jul 20, 2008
    MX310 does not reload the saved faxes in memory to the computer.
  • Anonymous Sep 09, 2008
    How do you convert faxes received (and stored inĀ
    memory) directly to computer?
There is no way to do that when i a fax is recieved through the printer. you could take the fax and then scan it and save a digital copy
Posted on May 14, 2008
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Jun 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Can you retreive a sent fax from memory
The fax element of the Printer contains a memory feature for storing faxes in the event of a printing problem. This feature is useful for protecting yourself against missing faxes if your printer runs out of paper. In order to retrieve missed faxes, the feature must be switched on when the faxes arrive. You can reprint faxes stored in the device's memory from the main control panel. You should allow approximately 5 minutes for this task, or longer if many faxes are stored in the memory.
Instructions:
Load paper in the input tray.
Press the "Setup" button on the front of the printer.
Select "Tools," then "Reprint Faxes From Memory."
Press "Cancel" to stop printing. Faxes are printed in reverse order; the most recent fax is the last to print.
Dec 03, 2010 | HP Office Equipment & Supplies
Memory is full
Please follow this instructions; i don't know whether you've disconnected or not but it's been disconnected from my side. So i just wanna give some more hints to fix your problem;
Press the Menu key on the control panel.
Press the Up or Down Arrow key until Fax appears on the LCD.
Then, press OK.
Press the Up or Down Arrow key until Remote Fax Opt or
Advanced Fax Operation appears and press OK.
Press the Up or Down Arrow key until Fwd/Page/Store or
Forward/Store appears and press OK.
Press the Up or Down Arrow key until Off appears and press OK.
If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Or
If you would like to reprint the saved faxes, press 2 (No), press
Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
Press the Menu key.
Then, press OK.
Press the Up or Down Arrow key until Print Fax or Print Document appears and press OK.
Press Black(Mono) Start.
After printing is finished, press Stop/Exit.
Good luck. Thanks for using FixYa.
Jun 01, 2010 | Brother MFC-5460CN All-In-One InkJet...
Fax machine saves incomign fax to memory, won't print
your looking for a com journal.. but this machine just says the number you sent it to not the photo of the first page
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
HP officejet 5610 all in one printer
You can download the manual from HP's website here.
You will need to configure the Fax machine to either auto answer or manually answer it to receive faxes. Generally Faxes are printed as they are received. If you have enabled Backup Fax mode the printer will store up to eight of the last faxes in memory, where they may be recovered by pressing Setup, then 6, then 5, then Reprint Faxes Stored in Memory.
Be aware that turning off the printer will clear all the faxes that are stored in the memoory.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 25, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax
From the manual:
If ink has run out while receiving a fax, if the paper size setting is incorrect, or if the paper type is set to a type other than plain paper, the fax is automatically stored in memory and <Received in memory.> is displayed. When the ink tank is replaced or the paper size/type setting is corrected, the stored fax is printed automatically.
Also, if the machine is in the process of something else (printing from computer, making a copy, scanning to computer), when a fax comes in it will be saved to memory, but it should print within a few minutes of becoming idle again.
May 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax in memory
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Oct 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Message on copier says Disk is full
Delete the files that you are storing in the printers mailboxes. Memory is only for spooling and printing but your hard drive in the unit is for storing documents back to a mailbox. That is where the documents that you scan and wait for print later are stored. or faxes can also be stored for a temp time and can fill up the hard drive. Try typing in the ip address into a microsoft explorer address bar and see if there is any utilities for this unit there.
Apr 09, 2007 | Canon imageRUNNER C3200 Copier
Canon PIXMA MX310 All-In-One Printer Logo
75 people viewed this question
old marine
old marine
