Question about Jenn-Air JJW8230D Electric Double Oven
I get Error Code E 01 when I power up my Jenn -air double oven. I get a repeated flashing 0:00 on the timer too.
3 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Dec 09, 2007
SOURCE: panel light is out
There is a capacitor on the clock board labelled C3. It will probably have brown burns on it or "syrup" leaking around the base. You can buy a box of 10 of these for 75 cents at Radio Shack (make sure you match the label on the old capacitor, I think it's 58mf and 35V but I could be wrong) and a pencil soldering iron for $10. It's held on with 2 little wires. Before taking it off note capacitor orientation (where the blue +++ stripe is), the replacement has to go on the same way. Common problem and easy fix.
Posted on Jun 21, 2008
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Aug 18, 2014 | Jenn-Air Ovens
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
Mar 24, 2011 | Jenn-Air Electric Double Oven
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-air ove3n flashing a error FR
hi friend,
error:FR
condition:second oven error sensed
resolution:1.check oven temperature sensor and hardness[or]
2.replace second board
hope this helps u
thank u for using fixya
please rate me....................
regards
sivaranjini
Sep 14, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
42 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
