Question about Dell Dimension C521 PC Desktop
Our internal CD drive/ CD and DVD Burner quit working. Will not even run a CD or DVD. Actually computer doesn't even recognize the drive. Is there a way to fix it or what kind of external drive should I get?
  • 22 Answers
2 things. Either the drive is dead or the dreaded microsoft registry bug has lost it. Here is the fix for the MS problem. If this doesnt fix it, its a dead drive and needs to be replaced.
  1. Click Start our internal CD drive/ CD - vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Hope this helps you. 9 times outta 10, this is the fix.
Posted on Sep 08, 2010
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
I need a driver for my backpack DVD +- RW model number 224010. Lost my installation CD and now have a new computer that doesn't recognize the drive
If you are using Microsoft, have you tried using the driver search tool? When Windows says it does not recognize a drive via pop up, click it to have the option for windows to search for the drivers online. If that doesn't work, you can manually search for drivers, which can probably be found on Micro Solutions' website. If the PC cannot detect any drive at all, then odds are the installation was incorrectly done.
Jun 01, 2011 | Micro Solutions Backpack DVD±RW...
Cd burner drive won't recognize dvd
You could spend $40 to buy a new CD/DVD reader/writer, or you could spend $50 to $75 for a computer-technician to _try_ to trouble-shoot. Your call?
Sep 17, 2010 | Acer (91.37H37.001) Internal DVD Drive
Samsung se-s084c and mac os x 10.5.8
Similar problem except worse. Can't even burn anything. Furthermore, disks inserted in the drive are not appearing on the desktop or anywhere. The drive appears in disk utility. It also seems to cause a host of other problems, various burning applications are CRASHING and not even responding to force quit (haven't tried to kill from terminal yet). We've had to reboot several times.
So far experience is awful. Going to return this if it computer keeps crashing everytime the drive is plugged in.
Macbook Pro (intel) with latest updates.
Feb 08, 2010 | Samsung External Slim DVD-W USB Compatible...
I need to fix a problem with my Sony DVD RW DRU- 180A. I get error code 39. The computer doesn't seem to recognize the DVD player.
More than likey a fault in the DVD player.
Did it work recently?? If so then probably faulty.
Check internal cable and even try another one, I have had the occasional cable fail.
Dec 22, 2009 | Sony DRU 180A - Disk drive - DVD RW ( R...
Acer Aspire 1690 DVD/CD-rom is not working
My cd/dvd rom dont work coz the drive has change to another one.I think take windows xp/vista/7/8 with an usb and inslat it. When windows finished installing try to format it because the dvd and cd rom are fixed . Thnx
Jan 16, 2009 | Acer (91.37H37.001) Internal DVD Drive
Mad Dog External DVD Writer
I don't know if I can be of any help here, but I purchased my Mad Dog Multimedia MEGASTOR DVD+/-RW burner a few years ago for my PoweSpec with XP Home Edition. I recently bought a new computer installed with Windows Vista Home Premium (which yes, I actually do love) and my external Mad Dog works perfectly, I didn't even have to update any drivers, it recognizes the drive everytime I plug it in (via USB). I don't need it anymore, but it's actually a better burner than the one that came with my system, which I bought new in March, although it's now discontinued. Do you have the disk for it? If so, have you tried running the disk again? What OS and processor do you have? In the event that it might be a matter of obtaining the proper driver for it to work for you, I also am a member of a great and extremely reliable site for free driver downloads. Free membership is limited to a few downloads within a certain period of time,and then you have to wait 24 hours, but other than that there is no limit so that's what I do. Just for the record, there was a period where my old XP was out of commission and I had to resort to my very old HP Pavillion that was about 10 years old, came with Windows 98SE(when that OS was brand new) and all I needed to do to make Win98 recognize the drive was download a driver and it worked just fine. LOL, that has a processor that runs at 600 megahertz, so you can imagine if my Mad Dog worked on systems like that, XP Home and now Vista Home Premium without a hitch, I was quite impressed with their products.
Aug 17, 2008 | Mad Dog Multimedia MegaSTOR...
Drive won't recognize discs
the blank media must be compatible with the burner drive that you're using... meaning if the drive is for CD-R you can only use CD-R blanks not CD+R. if the drive is CD-/+R then you can use either CD-R or CD+R
May 30, 2008 | Panasonic LF D311SC DVD-RAM/DVD-R Burner
Dell Dimension C521 PC Desktop Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
