Question about Samsung Refrigerators
Hi, I have a Samsung SR423NXB Refrigerator/freezer. We are having a problem where the refrigerator keeps freezing up, any ideas on the problem? Thanks
SparkGap
  • 363 Answers
SOURCE: Samsung RS2577BB Refrigerator/Freezer Will not Cool
Chances are you need to get the refrigerant recharged. This can only really be done by a professional due to the equipment needed. He will also find where the gas is leaking from.
Posted on Oct 13, 2007
SOURCE: Refrigerator freezes up
turn off
take all food out.
open door of freezer.
let all ice melt away.
remove cover over evaporator coil.
turn on.
should hear fan running.
if it doesn't, hot wire it with 110 v.
if fan no works with hotwire, replace fan.
if fan works with hot wire, find evaporator thermostat about 1 inch big
clipped on coil of evaporator.  short out ( put wire connecting its two wires ) .
if fan runs now, replace evaporator thermostat about $ 15
Posted on Oct 23, 2007
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
  • 400 Answers
SOURCE: samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Posted on Mar 09, 2009
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
Posted on Apr 28, 2009
I HAVE A SAMSUNG FRIDGE SIDE BY SIDE .THE FREEZER DOES NOT FREEZE IT SHOWS 19/20 C ..THE COOLING SIDE WORKS FINE..WHAT IS THE PROBLEM
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
Hi I have a samsung double door fridge, one side the freezer and the other the fridge with an icemaker and never used it. Model R526FANS and Model Code: R524FANS1/XFA and the freezer is on -25 degrees...
Greetings,
if the icemaker is disconnected and unplugged from the refrigerator will continue to operate and start to get to cold and sometimes freeze inside refrigerator...if you did not disconnect ,please let me know....Bruce Denton
Jan 05, 2011 | Samsung RS2630SH Side by Side Refrigerator
Hi, Our RA21VASS fridge with freezer box seems stuck on the coldest setting after defrosting. Everything in the fridge compartment is frozen and the temp knob appears not to work. Any ideas?
heatman101
Dec 15, 2010 | Samsung Refrigerators
Freeze doesn't freeze and fan in fridge is now making noise
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung RB1955VQ Bottom Freezer...
Refrigerators Logo
78 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
