Steps on taking the keyboard off the laptop - Computers & Internet
  • 3 more comments
  • S1LV3R
    S1LV3R Sep 08, 2010
    You need to be a little more specific. Every laptop manufacturer is different. Make and Model of laptop please
  • joecoolvette
    joecoolvette Sep 08, 2010
    Generally for most laptops the strip of plastic above the keyboard, and below the LCD screen, is removed. There may also be one, or two screws to remove from the bottom of the laptop, that run up through the laptop to the keyboard. Post the laptop manufacturer's name, and the model number. (Post in a Comment) I may be able to give you a link to the Service Manual, as well as written guidance from me.
  • gordonspud Sep 08, 2010
    HP Pavillion dv9000. We put a new screen on but now that we put it all back together it turns on but the screen does not work. So we took it apart and checked the wires and then it worked. Put it all back together and now the screen does not work again. We are thinking that it just may be a bad connection in one of the wires. Do you have any suggestions? When the screen did work, it stopped working when i put the six screws back that go in the battery area. I appreciate your help and suggestions.
    It is a HP pavillion dv9000
    I am sorry it is a dv9922. the screen is the dv9000
  • Computers & ... Master
  • 5,660 Answers
1) The Pavilion dv9000 you're referring to is one of the Pavilion dv9000 series. The specific model number is on the bottom of the laptop, in a white Service Tag. P/N is Product Number. HP's model numbering system.
Just posted for future edification should you have problems with another laptop. All Model Numbers will be on the bottom of the laptop, HP or no.
2) I would like to start with a link to the Service Manual, for your Pavilion dv9000 series laptop.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1842189&
On this page scroll down to - HP Pavilion dv9000 Notebook PC - Maintenance and Service Guide, and left-click on it.
This is a PDF file.
May take up to 30 seconds before you see the first page. Additional time to fully fully download.
(Took 18 seconds to see the first page, and no additional download time, for me just now. Medium speed DSL)
Agree. Your diagnoses leads me to believe the Display Cable (Wire) has a break in it.
Switch Cover removed, (Plastic strip on top of the Keyboard, and below the LCD screen, I referred to before), the Display Cable is the cable (Wire) to the far Left. (Long connector) The cable next to it on the right, is the Microphone cable.
(Short connector)
(Next cable going to the right under is under the Keyboard, {But not connected to the Keyboard}, is the Camera cable. The long cable coming from under the Keyboard, and going off to the far right top corner, is the Wireless Antenna cable.
Also check the Backlight cable. This is the cable on the right side of the LCD screen, and goes to the Inverter mounted inside, at the bottom of the LCD Top Panel Cover. (The Lid, in otherwords) When you state your display does not come up, I assume you have checked the LCD screen with a flashlight, to see if the problem is just the Backlight Bulb is not working. An LCD screen does not provide enough light by itself. Needs that type of Florescent light bulb, (CCFL. Cold Cathode Florescent Lamp), to fully illuminate the LCD screen.
If the Backlight Bulb cable has a break in it, you won't be able to see the display.
Good news?
Hmmm,
Not much I'm afraid, unless you're really good at soldering, or HP does indeed still sell that display cable, if it's bad. It's a multi-wire cable.
The Display cable also goes down through the laptop, and connects to the motherboard. You have to almost completely disassemble the laptop, to get to the display cable's connection on the motherboard.
Laptops are disassembled from the Top going Down. You do not just remove the Bottom Cover.
Things I would like to suggest.
FOLLOW Anti-Static Precautions, before you go any further into your laptop. (If you aren't following them already)
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out Short Circuit) the delicate hardware components, inside a computer.
Relieve your body of Static BEFORE going deeper into that laptop.
With a desktop computer you just unplug it from power, and Touch the metal frame of the open computer case. The frame is made of steel.
The metal used inside a laptop is non-Ferrous. No Iron. Makes it so that the metal is non-magnetic. Also will not work for relieving your body of Static.
You can touch a doorknob to relieve your body of Static. The door better be within a one-step distance from where you're working. The movement of your feet, the rustling of your clothes, are 2 things that create Static.
Better method is to buy, and wear an ESD wrist strap, and connect the alligator clip to the metal frame of an open desktop computer case, unplugged from power.
[Electro Static Discharge. They run about 6 bucks)
In the PDF Service Manual ('Guide'), in the Bookmarks on the left side, scroll down to the section heading, Removal and Replacement Procedures, and click on the + sign to the left.
Now click on - 5.24 System Board. (Or Page 191 for the PDF page number)
Takes you through completely disassembling your laptop.
Check the Display Cable with a cheap multimeter set to Ohms. You are performing a Continuity Check of that cable. Wiggle the cable when checking with the multimeter.
Post questions in a Comment.
Posted on Sep 08, 2010
How to remove and insert MSI PR400 Noteboo stuck keys
Watch these videos to remove and insret keyboard:
Acer Aspire 5536 7740 5251 Laptop Keyboard Installation Replacement Guide...
How to Install Zawgyi Font Keyboard for Windows Computer Myanmar Version
How to replace laptop keyboard
Dell Inspiron Laptop Keyboard Installation Replacement Guide 1525 1545...
Beware of replacing your keyboard if you don't have some experience manipulating laptops. You might end taking it in a shoubox in pieces to your repair service!.
Take a photo of each step you do,.
Oct 05, 2015 | MSI Computers & Internet
Tip
How to replace the Hard disk in Dell Mini Laptop:
* Turn off the computer and take the battery off the computer
* You will have three screws below the below the battery - Take them off
* Then open the laptop and try to take the keyboard off the computer
* The keyboard will have a strip in the backside - Please take it out of the strip carefully
* Now you will be able to see the hard drive in the left side under keyboard
* Take the two screws holding the Hard drive
* After you replace the hard drive - connect the keyboard strip and put the keyboard in place
* Back of the laptop put the three screws and then the battery back in place
* This is the simple steps that you can use to replace or take the hard drive off
on Oct 22, 2010 | Computers & Internet
Tip
How to Repair, Replace and Change HP Laptop Keyboard
We are surprised that HP has done a nice job taking laptop market share from Dell and launching a slick marketing campaign using the slogan "the computer is personal again". Hewlett Packard laptop computers feature the functionality of a desktop computer in regard to their keyboards. However, because of size limitations, some laptops feature special keys that serve specific functions. Using these particular keys requires only the development of some new keyboard habits, like locating and pressing the "fn" button. With many HP laptops, the "fn" button is encircled.
When a key fell off the laptop keyboard, most likely you can fix the keyboard. It often comes: using a small dab of super glue to replace keys that have fallen off and then placing a small dab of glue directly on the round part that holds the key in place and lightly press the key down. When the glue dries, you’ll be able to use your laptop again.
However, not all problems can be fixed this way, and a keyboard replacement for a laptop may be necessary. Besides, this is not an overly complex process on an HP laptop just with simple steps.
Step 1 Power down your HP laptop and Flip over the HP laptop and locate the RAM section. Press the HP battery release lever and pull the battery out of the laptop. To remove the battery on most laptops, you'll just push a release tab and pull the battery out of the connectors, but with some you'll have to remove screws. You'll know what to do once you get ready to disconnect the battery.
The RAM section is in the bottom center of the back of the machine. Use your Phillips-head screwdriver and remove the two screws securing this cover. Remove the cover.
Step 2 Use your Phillips-head screwdriver to remove the rest of the keyboard-related screws on the back of the laptop. There are three silver screws and five black screws to take out. The three silver screws each have a keyboard icon printed next to them. The other five screws are aligned at the top of the laptop back and beneath the battery.
Step 3 Use a flathead screwdriver to pop up the HP Keyboard shield. Wiggle it under each side of the shield and carefully pop it up. The shield is located at the top of the front of the laptop (just above the keyboard itself). Place it aside and out of the way, since this shield can be easily damaged or warped after it is removed.
Step 4 Pull up on the keyboard carefully and slowly. Do not pull all the way; otherwise, you may damage the cable underneath. There is a keyboard cable holding the keyboard in place. De-attach it from the unit by locating the connector beneath the keyboard. Flip the connector lock into the up position and disconnect the cable. Remove the keyboard.
Step 5 Take the new keyboard and attach the keyboard cable to the connector, and push the connector down. Slide the new keyboard in. Replace the keyboard shield.
Step 6 Turn the HP laptop back over. Replace the set of five black plastic screws, and then the three silver screws. Replace the RAM cover.
A quick notes, when you unscrew the screw on the bottom of the laptop, just remove the screw with a "keyboard icon", not unscrewing every screw you see!
Related: Papatek.com offers a complete line of HP keyboards and compatible replacements for most laptop models.
on Aug 25, 2010 | Computers & Internet
Computer come on but keys are lock can type pass work , water from iron leak into key board not a lots
This is a pretty common thing to happen. Here's a few options for you.
IMMEDIATELY, take the battery out of the laptop and unplug it! Water and electricity don't mix. After removing all power, take the laptop and put it into direct, full sunlight for several hours to try to dry off any remaining water.
The next day, try to see if the keyboard is still fried or you got lucky and its ok now. If it still doesn't work, you've got a couple of options:
1) This will likely require the replacement of the keyboard. If the laptop is older and you don't want the trouble or cost of replacing the laptop, you can usually just purchase a USB keyboard. Plug it into a USB port on the laptop and your problem should be solved.
2) If however the laptop is fairly new, and you want to replace the keyboard, you can either do it yourself (really NOT a huge project) or bring it in and have someone do it for you. If you opt to try to do it yourself, here is a link to a site with step by step instructions to remove the keyboard: http://www.insidemylaptop.com
This site is full of tips and step by step instructions to replace things like keyboards. Once you get it off, you can then Google 'laptop keyboards' and you'll find dozens of places that will ship you a replacement keyboard in a couple of days. Then just reverse the process to remove it and she should be all set.
3) The other option if you're not feeling brave is to take it to someplace like Best Buy's Geek Squad and have them do it.
Best of luck! Hope this helps!
Jun 21, 2011 | Computers & Internet
HP LAPTOP G-60 630US KEYBOARD PART # 496771-001 HOW DO I TAKE THE OLD ONE OUT
Do it carefully..at your own risk..
HP 496771-001 Keyboard Repair and Replacement
Are you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick HP 496771-001 Keyboard repair tutorial with step-by-step instructions.
Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the HP 496771-001 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the HP 496771-001 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire HP laptop keyboard.
Final step: To insert the new HP 496771-001 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the HP 496771-001 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
Ron
Feb 12, 2011 | HP Computers & Internet
How to to take out the keyboard on a Gateway laptop computer model #m505B2
look on the bottom of your laptop you should see screws with a small keyboard logo next to them you must remove all of these screws in order to remove your keyboard also check youtube for tutorials so that you can walk through step by step in case you get confused
Sep 23, 2010 | Computers & Internet
Have to replace the keyboard.
Hello dgb_w0ddw,
Have you looked at the YouTube video examples for replacing laptop keyboards ?
http://www.youtube.com/results?search_query=replace+laptop+keyboard&aq=1
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Apr 29, 2010 | Toshiba Satellite A105 Notebook
Replacing keyboard in a Toshiba P505 S8945 laptop and looking for step by step instrucstions.
Removing the keyboard:
STEP 1 - Turn off the laptop, unplug the power adapter and remove the battery. In the battery compartment remove three screws securing the keyboard bezel.
STEP 2 - Remove the keyboard bezel with a small flathead screwdriver.
STEP 3 - Remove two screws from the keyboard.
STEP 4 - Lift up the keyboard as it shown on the picture and place it upside down on the palm rest.
STEP 5 - Unlock the connector on the motherboard and release the keyboard cable. Remove the keyboard.
Reverse these steps to install new Keyboard
www.irsivista.com for Toshiba Disassembly Guides.
Jan 14, 2010 | Toshiba Satellite P505-S8945 Notebook
Patriot 2005 laptop keyboard replacement
look in the back of the computer... youll probably have to take most of it apart... may i recommend you take camera phone pics of each step to assure that you get things replaced in the same manner.
Sep 13, 2009 | Computers & Internet
Keyboard
lay the screen all the way back ,and with small screw driver take off hinge coverings which should open up entire uppper key board assembly,then unscrew small screws lift keyboard and remember to detach scuzzy cable for key board. you done
reverse for reinstalation .. la la linda
Apr 26, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
