Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
How do I start the self cleaning process - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • Frigidaire Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Sep 08, 2010
Why can't self cleaning be initiated?
you sure it is not LOCK doors ?
the doors usually need to be locked to start the selfcleaning process, you must have a little lock near the main handle to lock it
Apr 12, 2016 | Ovens
How do I start bosch exact temp self cleaning oven
My Bosch is also self-cleaning. If you press and HOLD the 2 buttons Bake and Broil that will lead you through the process. It starts by beeping at you- don't give up. :D
It will remind you of several things:
Choose length of time (4:00 is standard)
Remove the racks (self-cleaning will make them 'sticky'
and so forth
Keep pushing Start if you are comfortable moving forward.
Hope this helps!
Apr 28, 2012 | Ovens
I started the self cleaning process with the timer, however, there was a light fire in the oven due to grease. My husband turn the oven (self-cleaning process) off by turning the circuit breaker off. ...
if the door is unlocked then clean all the grease and let go, if the oven is still locked then get a tech down to your house to have it unlocked since its not safe to have it run again with greaase
Sep 05, 2011 | Magic Chef 9512 Electric Single Oven
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
I have an older model gibson self cleaning oven. How do I start the self cleaning process. No manual. Thanks.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 25, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I do not know how to start the self cleaning process. I lock it, but no light comes on to show it is locked...and when I turn both dials to clean, nothing happens.
There is an interlock switch that engages (or is supposed to) when you operate the locking lever in the self-cleaning cycle. This starts the self-cleaning process. It sounds like the interlock switch may be bad. Make sure you have selected the Clean cycle.
However, before calling for repair, disconnect power from the appliance for about 30 minutes, turn it back on and try again.
If still no luck and you are sure you have slected the correct cycle, then it may be time for repairs.
Feb 08, 2010 | KitchenAid KEBC107 Electric Single Oven
I used the self clean option and now my oven will
There is a thermal fuse inside the rear panel of the oven that frequently blows when using self clean option. This is where I would start looking.
Sep 30, 2009 | KitchenAid KEBC101 Electric Single Oven
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven would not open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jun 24, 2008 | Tappan 30IN ELEC IGNa Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
102 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
