Question about Intertherm Heating & Cooling
Electrical diagram for model # e2eb-015 ha serial e2e9710-05442 replaced heat sequencer. Think heat and a/c running at same time. Inside coil froze up all the way to outside unit. Need electrical diagram for inside unit.
Sea Breeze
  • 4654 Answers
SOURCE: non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Posted on Oct 28, 2007
hotuna
  • 288 Answers
SOURCE: ruud heat pump outside fan
You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
Posted on Mar 15, 2008
The HVAC Guy
  • 30 Answers
SOURCE: Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Posted on Oct 30, 2008
  • 96 Answers
SOURCE: heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Posted on Dec 10, 2008
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
I have a Nordyne E2EB 020HA Electric furnace. There is barely any heat coming out of the registers. Fan is blowing constantly. When I heat the room up with electric heaters, and the thermostat hits desired...
The easiest way to check is with a clamp on amp meter. 5kw heater is approximately 20 amps. 10kw is 40, 15 kw is approximately 60. Measure the amps on 1 line (main power) wire entering machine. It could be a sequencer it could only be running on single stage it could be the element, the amount of heat, the fan speed, many things. But, checking the amps is a sure, easy way to tell if all of your heat is working. Keep us posted, we can advise.
Sep 04, 2017 | Heating & Cooling
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
I put new fan motor or heat pump now runs all time and doesat seem to heat well but line set going into a coil infurnace is hot
I would check the fan relay and especially the sequencer. I recently came across a problem with an older sequencer which had come partially apart and allowed the thermo disk to keep the fan running continuously. The sequencer controls not only the fan relay (24 volt), but the heating strips(220 volt) as well. Make sure all power is off to the unit and verify. Make a wiring diagram and take several pictures if necessary. Replace sequencer with only an Identical unit, even if you have to order it. The newer sequencers have two metal straps to prevent this problem from occurring.
Feb 15, 2011 | Heating & Cooling
Froze on the cooling cycle and will now not even turn on
If your AC froze up that is usually a dirty filter or coil, blower not running at proper speed or at all, or low on refrigerant. Since you say it won't come on at all now, that's probably an indication that you are low on charge and now you don't have enough pressure or refrigerant to close the low pressure switch. You will need to have the refrigerant charge checked.
May 07, 2009 | Intertherm P3RA-042K Air Conditioner
Need help bad!!!!
try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Jan 04, 2009 | Heating & Cooling
Blower will not come on
could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
Jan 04, 2009 | Kitchen Appliances - Others
Heat comes on fan does'nt
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
