Question about Frigidaire ATF6000ES Front Load Washer
Washer Problem We have a code of E41 coming up on the washer. This was after getting a code of E20. We cleaned out all the hoses, and checked the water flow. That is fine now it is saying the door is open. How do I know if it is the control board or not, and how do I fix the door? Not that we don't want a tech. to come out, but the timing isn't the best for us to be spending it on that. What can I do intermittently?
  • 868 Answers
Change the door latch assembly first.This will most likely be the answer.Its a electrical locking catch that the door locks into.The error code is very accurate on this model so change the DOOR LATCH ASSEMBLY first,I'll be happy to guide you through this if you need me.
Posted on May 21, 2008
  • Lisa Glass Oct 21, 2011
    I have the same error showing. ordered a new door latch; easily installed it but the washer still shows the same error!! i push start, makes the noise like it will start then "dr" flashes and the machine beeps. What to do????
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Error Code E20
e20 is a draining issue.check your filter is clean.if this is ok suspect a bloackage in the waste hose or faulty or jammed drain pump impellor
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code E20. This is not listed on the error code chart. What do I do to fix the problem.
E20 means the drain hose is plugged or kinked or the household drains are plugged. YOur washer will not drain and spin until this is fixed.
turn off the washer/unplug it/remove the drain hose and check for a clog. If it is there, clean it out. If not - check your sinks and toilets for slow running drains. The garbage disposal is a good place to start as well. plug the sink, fill it with hot water, then pull the plug and start the disposal. That will help clean the disposal and also show you if you have a drainage problem there. Plunge the toilets, etc.
Good luck to you!
Aug 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
If your machine is stuck on the drain sequence or you read error code E20, the filter basket is probably clogged:
You will need a pair of slip-joint pliers and a Phillips head screwdriver.
Before beginning any work, make sure to unplug the machine from the electrical outlet.
**Note: It may be easier to perform this task with the washer lying on its side; therefore it may be necessary to disconnect the water lines from the machine.
1: Take off the front kick plate (two screws at the bottom of the machine).
3: There is a black accordion hose with two clamps.
2: Have a towel ready to catch the water that leaks.
4: Remove the clamps at each end to access the filter basket.
5: Stick your hand inside the hose and remove the plastic filter basket (it will probably be clogged with hair, lint, fabric).
6: Thoroughly clean the filter basket and remove all debris from the inside of the black accordion hose.
7: Replace the filter basket.
8: Reattach the black accordion hose at both ends.
9: Secure the clamps at each end of the hose.
10: Wipe up any water that may have spilled inside the machine.
11: Reattach the front kick plate with the two screws removed earlier.
12: Reconnect all hoses before plugging in the machine to the electrical outlet.
** This took me about 30 minutes from start to finish.
Feb 16, 2008 | Frigidaire ATF6000ES Front Load Washer
My washer wont spin out it has a code that is E20
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 12, 2008 | Frigidaire GLTR1670A Front Load Washer
Error codes
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Dec 28, 2007 | Frigidaire FTF530FS Front Load Washer
Firgidaire washer
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Dec 11, 2007 | Frigidaire Affinity ATF7000E Front Load...
E20 message
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Dec 02, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Frigidaire ATF6000ES Front Load Washer Logo
506 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
