Question about Mitsubishi VS-6047 60" Rear Projection Television
TV problems I have one of these Mitsubishi 60inch TV's (VS 6047) and the screen wobbles in and out. Basically this is very noticable when you have something consistent on the screen like a sports score. Does anyone know what causes this and approximate costs for fixing it? Thanks
I have a mitsubishi HDTV 1080 Integrated and the speakers are off and I can't get it back on
Posted on May 27, 2008
I am about to buy a used 60inch Mitsubishi big screen TV...there's a little scratch on the screen is this something that can be fixed easily?
No, if the screen is scratched it would have to be replaced---most are well over 100 in cost---if not too bad this should be a bargaining point to use---set not worth as much with scratched screen.
Out clear screen is protective only and anti glare as well.
Do not try to sand or buff it out--It will just make it look worse.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 19, 2010 | Mitsubishi VS-55609 55" Rear Projection...
Why does my sound come on but no picture, then picture after several minutes?Mitsubishi vs-6047
it sounds like a component is going bad. i have known a flyback transformer to act like this before going out
Nov 10, 2009 | Mitsubishi VS-6047 60" Rear Projection...
The tv clicks on but it clicks right back off why? its a vs 6047 model mitsubishi
I am not familiar with this particular TV model, but what you describe is usually the power supply switching the heavy current circuit on and then switching it off in a few seconds since it does not detect the high voltage it expects and presumes there's been a short circuit somewhere.
Most of the times it's not actually a short circuit, it's either a blown fuse or an element that went completely open and prevents the power supply from working.
Nov 03, 2009 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-6047 60 in
pull the front panel off, remove the 4 screws holding the inner panel on , then with a screwdriver gently touch the wires leading to each of the the projector bulbs one of these is not getting a good connection , it is the one that has about 6 wires leading from it
May 12, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Feb 11, 2008 | Mitsubishi VS-6047 60" Rear Projection...
1995 mitsubishi 60inch big screen
Probably a solder issue. try soldering around the flyback, line coilsand vertical and yoke plugs. You can get a service manual for 10.99 emailed to you at the following link. they also offer free support to help with the diagnosis of your Set.
http://servicemanuals.vstore.ca/
Feb 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Burnt Resister
where are these resisters located and whats the part location number on the board
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Televison & Video Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
