Question about Char-Broil Commercial Stainless Steel Grill
I have a char-broil commerical gas grill and the push button ignitor is not pushing in. What is the problem
  • 494 Answers
If the grill has been sitting out in the weather, sometimes it just gets corroded inside and sticks. Try spraying WD-40 inside it while pushing it and see if that does the trick. If not, they are very inexpensive and can be purchased at most hardware stores. Douglas
Posted on Sep 09, 2010
How do I take off the ignition button from the front of my char broil red gas grill to change the battery?
It is not necessary to remove the whole ignition module. Just unscrew the plastic ring around the rubber push button. The battery holder is inside that. Be sure to install the new battery facing the same way the old one is.While the old one is out, check the contacts inside the battery holder for corrosion. If you see any, a Q-Tip and WD40 work well to clean it OFF.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 27, 2011 | Char-Broil CharBroil 4637318 Grill
How to you start it
Grill should have a push button igniter located on control knob panel. The ignitor requires a battery, usually AA. Remove the cap and put in battery. Make sure propane tank has propane and turn on. Make sure all connections are tight. You can also manually light it by going through the view hole located at bottom front or side. Make sure your match or lighter is in and lit before turning on gas.
Jun 20, 2011 | Char-Broil CharBroil 4637318 Grill
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Need a new ignition swicth. year 2005 model DHLB
Whether it's electronic ignition or the old, standard, push button piezo ignitor, you can find it at the Char-Broil Parts Link below.
Happy Grilling!!
May 20, 2011 | Char-Broil Commercial Stainless Steel...
How do I attach the ignitor wire? where do I do this...I know it's @ B but where?
The single ignitor wire should attach at the back of the "push button" starter. It will be on the front panel and probably says "push to light".
Jan 05, 2011 | Char-Broil CharBroil 4637318 Grill
Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Jul 02, 2010 | Char-Broil CharBroil 4637318 Grill
My grill won't light. I have new propane and when I turn it on and push the button it clicks but no flame. Any suggestions? Thank you
First thing can you hear and smell propane running. If you can then try and start with a match. If this works your ignitor is probably dirty in the grill area. Where wire connects under grill look at the metal that this is connected to, could be dirty with grease or just needs to be bent closer to metal that it sparks off of. If this doesn't work then ignitor button is bad and needs to be replaced. You can buy at lowes or home depot.
Jun 13, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
Gas grill ignitor no longer ignites burners
it is bad you need a new igniter, the flint part goes bad
Feb 20, 2009 | Grilling
Char-Broil Commercial Stainless Steel Grill Logo
155 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
