Question about True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F
My fans in freezer stop working. fans on condenser and compressor not running. compressor is cool. i changed relay but not working i am not getting ground on the inside
  • True Master
  • 1,252 Answers
I would check for a bad neutral in the system. Look at the recepticle first. It may be just that simple.
Let me know and we can go further.
Posted on Sep 08, 2010
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
Is there anyway to test start relay for a freezer
Hello - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 30, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer is not getting any where near cold or frozen. compressor seems to be on and fan runs. please help. thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Caravell 5.5 cu. ft. / 156 liter Chest...
My chest freezer recently beginonly freezez a little at the top but it 's just cool like a fridge at the bottom
Hi and welcome to FixYa. I am Kelly. This freezer uses the chassis to dissipate heat so that the freezer can freeze. There is not a condenser fan. So what you have is a basic and usually trouble free freezer. If your freezer is not cold at the bottom of the unit there can be a couple of causes:
1. The compressor is running slow due to the rotor dragging on the compressor stator.
2. The PTC relay contacts on the compressor are getting hot and the compressor is shutting off before the temp control cycles the compressor off. Usually that is how PTC relays fail.. one hot contact and the unit cycles much more rapidly than usual and eventually the compressor stops running completely.
3. The system Freon has leaked out of the system and the unit is running on low pressure. (If this is the case the symptom will only get worse and very soon)
4. There is a very remote possibility of the cold control being damaged from an external bump by someone due to the fact that it is located outside the freezer compartment on the chassis.
Thanks for choosing FixYa. Kelly
Jul 09, 2010 | Magic Chef Chest Freezer MCCF5WBX
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F Logo
147 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
