Question about eMachines ET1161-03 PC Desktop
How do we connect the speakers properly to ensure sound. Thank you Beth Donovan
    Sergeant:
  • 286 Answers
There is already speaker out jack or symbol is there where u have to connect ur speaker.
Posted on Sep 08, 2010
Laptop speakers picking up interference?
The speaker may not be making proper electrical connection to the motherboard.
Reseat the speaker connection to the motherboard.
Jun 04, 2012 | Dell Latitude E6510 Notebook
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
I have a new reformat pc all installer sofware are working properly but soundcard installer is not working on my computer. hoe can i fix tihs problem, and how to fix this easely? thank you so much god...
Well, try this.
Ensure speakers are connected to the correct port. Usually the green one on your sound card. Then --
Open Control Panel, Device Manager.
Expand Sound, Video and Game Controllers
Right Click your audio device and select Properties.
Does it say, THIS DEVICE IS WORKING PROPERLY in the Device Status box? If not,
Click the Driver Tab and select Update Driver.
If yes, Go to Device Manager, Sound
On the Playback Tab, is there an Audio Device listed and selected? Is it the correct one?
If yes, select the Sounds Tab. Select a Sound Scheme.
You should now have sound. If not, recheck your connections. If all is well, replace your sound card.
Nov 27, 2010 | Intel Pentium D 820 2.8ghz Dual Core CPU -...
No audio output devices
check to ensure the sound card is properly seeded and connected
Oct 25, 2010 | Computers & Internet
No speaker sound
There sometimes are three connectors on a sound card that are similar. A speaker output, microphone input, and stereo headphone output.
Try all three, if you accidentally put it on the microphone input you won't get sound output of that one, so try another.
Also, check in the speaker control panel for the sound to be checked to mute or volume turned all the way down.
Aug 01, 2010 | Dell Dimension 8200 PC Desktop
HELP speakers aren't working
Hi
Thank you for your query
Please try the following
1) Ensure your speakers are correctly plugged into the back of the PC they should be plugged into a light green port
2) ensure the volume control on the speakers are turning and you have set them to a decent level
3) Click on Start>Control Panel>sounds and audio devices and ensure the volume is up and the volume is not muted
Please try the above
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Altec Lansing VS2121 Computer Speakers
No sound
Try a reload, occasionally a conflict of shared files knocks it out.
Jan 07, 2010 | Microsoft Windows XP Home Edition
I have dell speakers hooked up to my dell pc but NO sound.
  • Ensure the connection first if the connectors are hooked up to the correct port.
  • check if the speaker is receiving the power there should be an indicator lit up
  • If you have an integrated sound card make sure they are not disabled in BIOS.
  • Then check if the sound drivers are properly installed.
  • check the volume control to ensure if mute is checked(uncheck it) also ensure the volume level it needs to be set to a level so that it's audible to you.
  • Do check the speakers with another devioce to ensure the speakers are fine and working.
  • FOR MORE SPECIFIC INFO PLEASE PROVIDE THE MODEL AND BRAND DETAILS OF THE PC AND SPEAKER AND OS
Feb 21, 2009 | Dell Audio Players & Recorders
Speakers not working on my acer al1714 computer screen
For no sound issues please ensure if the speakers are working fine by connecting them with a known good device other than the computer...
If they are fine then please check the connection of the speakers if they are intact (for details on connection please check the manual that came with the speakers...if its a two set of speaker the left connects to the right and the right connects to the power and  another connector goes to the line out which is green in color at the back of the computer)and if the speakers are receiving the power properly also if the volume level is set to a level that can be heard...please ensure that the audio is turned on in BIOS if the computer has and integrated soundcard....when the computer boots to the desktop check volume control to see if any of the mute option is checked if so uncheck it and also setthe volume level to high...in case the volume control doesnot open you will need to install the sound drivers...also ensure that the windows audio service is started in services you can check the same by clicking start>run>type"SERVICES.MSC">WINDOWS AUDIO if not started or disabled right click go to properties and then enable the service and click start.for the appropriate driver please specify the soundcard or if integrated then specify the motherboard details
Jan 27, 2009 | Acer AV009 Computer Speakers
eMachines ET1161-03 PC Desktop Logo
264 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
