Question about Whirlpool Duet GHW9150P Front Load Washer
I have the duet and my wash machine is saying f21 lost my manual
  • 347 Answers
F 21 is an error code for long drain if the unit takes 8 minutes or more to drain it will set this code.Firts thing is put it on drain spin and see if you can get out most of the water,take off lower front panel,three screws at very bottom.now you can see the pump its right their in front, lay down some towels water WILL come out and unscrew the cap on front of the pump pull out and clean,and reinstall if it was full of gook you have probably fix the problem if not something may have gone thru and damaged the pump... Hope this helps Good Luck
Posted on Sep 08, 2010
How do i get a "whirlpool duet washing machine" to unlock its front door
Your answer is here in this youtube video.
Your problem is the washing machine still has water in it, so it locks the door.
Whirlpool Duet washer will not drain F21 Error Fix VERY EASY
Sep 03, 2015 | Washing Machines
Have a code F21--What is wrong and how do I fix it?
This site has a good solution, assuming this is your brand name of machine... but the solution might apply to you otherwise:
http://www.managemylife.com/mmh/questions/230239-front-loader-washing-machine-whirlpool-duet-broken-says-f21
Oct 18, 2013 | Washing Machines
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My duet front load washer has an F21 code. The washer does not drain. The manual says to check the drainage hose for a clog. I disconnected it and water runs freely through it. I'm still getting the...
Have you checked the filter, hose, and plumbing where drain hose goes to?
If you have and none of these are blocked then you have a faulty drain pump which will need replacing
Jan 27, 2011 | Whirlpool Duet WFW9550 Washer
F21 Whirlpool duet washer, removed front panel unclogged restarted and still f21? Tech came in and had no idea said he smelled something burning, must of been his imagination.
ohh, duets are such a treat.
If the drain time exceeds eight minutes, “F21” will be displayed,
the water valves will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be
cleared and the machine will turn off after a maximum of eight
minutes.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
this is what Whirlpool says, but we have found that this doesnt always work.
Nov 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal De
