Question about Tascam DA-30MKII
Where can I get tapes for a tascam da -30 mk2 and what are the tapes sizes?
    Sergeant:
  • 357 Answers
You need what are called "DAT TAPES". Just like Blank analogue audio cassettes they come in a range of lengths fro 15min to 180min. You'd be better off to use something like a 60 or 90min IMHO. Dat tapes can be purchased from places like "studio spares" or any other PRO media supplier. They can be quite pricey. I tend to buy mine in bulk on ebay.
Before you ask, not there are not different tapes for different machines, but the btands do vary. I use either HHB or AMPEX. DO NOT USE COMEPUTER DATA BACK UP CARTRIDGES as a cheap alternataive.....they are different and end up giving you a lot of loss and errors over the years...sometimes instantly (Tale it from experience!)
Best Of Luck
Posted on Sep 08, 2010
Hi, I have a tascam 112 mk2 that doesn't play. the play, pause and record lights just blink and it makes strange sounds. tape inside that I can't get out. question, how can I eject the tape safely ?
The tape needs to be extracted by a Technician as getting it out any other way can damage the machine. I see these failures all the time and is due to old grease and a broken Gear C. I have these gears custom made and am one of only two sources for them now world wide.
Jan 04, 2018 | Tascam Audio Players & Recorders
How do I fix a Tascam DA-38 Multitrack Recorder?
It needs cleaning and new belts some of which are very hard to find because they are smaller than a dime. It can be fixed if the Pinch Roller is not cracked.
May 30, 2015 | Miscellaneous
Need belts for tascam 102 mk2 cassette player
This is easy to take care of just contact Marrs Communications and select the
Supreme" CASSETTE KIT $19.95
http://marrscommunications.com/tascam-cassette-kits
Oct 11, 2011 | Tascam 102 MKII Single Dual Cassette Deck
TASCAM DA-30 tape transport error
When you use any cleaner or lubricant it must be only for the moving part and must never stray into the transport section. Also what is required if there is any frictio is to dry wipe and set. Now when you lubricant got sprread into the head, the oil will act as a great adhesive at higher speed and got the tape entagled. So please wipe dry all the oil of the headd and do nto damage the head with the wipe touching the delicate ferrite heads in the slot, DO NOT TOUCH THIS SECTION but with an even paper with soft brushes. Now check you reel drive and see if there is dirrt lodged in clean and reset., put the set on for regaining lost values as many electronics capacitors may have lost value by drying. If the tape up does not move it is a mechanical problem and you must check for the drive and the friction wheel. If however the reel works and the count does not happen and you get the error , then your reel sensor is faulty. Check these points and confirm, Hope this advice helps, Good day.
Jul 23, 2010 | Tascam DA-30MKII
I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Dec 03, 2009 | Tascam Audio Players & Recorders
Tascam da30
www.datrecorders.co.uk/da30.pmp has a pdf version you can download for a fee.
Apr 12, 2008 | Tascam DA-30MKII
Need a tec to repair
I can help you if you are in Queensland Australia. :)
Jan 19, 2008 | Tascam 122MKIII Single Dual Cassette Deck
NEED TO FIND A REPAIR SHOP YEP I NEED A FIXYA
I'm in Vermont and have 25+ years into it and good references
painintheamp@yahoo.com
DA-88 tape problem
seems like you have a blank tape there.
Sep 03, 2007 | Tascam Quantegy 120 Minute Digital Audio...
Electronics - Others Logo
188 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
Lyle Siemens
Lyle Siemens
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
