Question about Sony RCD-W500C 5-Disc CD Recorder
When u put a blank CD in it will say blank disc when you push REC. it will say Data disc and with a different CD it will say -79.59 e-mail me at j.smedley@moreheadstate.edu
    Sergeant:
  • 334 Answers
I think your problem is that you are using a blank CDROM type disc in a CD Audio recorder. If you "burn" cds on a computer, it does not matter what type of cdr you use, but if it's for a stand alone CD Recorder (that you ise with hifi/dj stuff) you MUST use CDR AUDIO discs (sometinmes it will even say FOR MUSIC)
Posted on Sep 08, 2010
  • adrianbogane Dec 09, 2010
    These days, a disc can be labled for "music,"
How to properly get this item to record?
search google with make and model of it then manual
Mar 08, 2015 | Audio Players & Recorders
Tip
Burn a Data CD or DVD in Windows 7 Using Media Player
You can burn a data CD or data DVD in Windows 7 using Media Player. An audio CD can contain just approximately eight minutes of music. On the other hand, if you burn a data CD or data DVD in Windows 7 using Media Player, it will be able to hold numerous hours of music. Video files and pictures can also be added to the data discs.
When you burn a data CD or data DVD in Windows 7, the Windows Media Player does not transform the selected files to a different format prior to saving them to a blank data disc, so the files stay in the compressed condition. This allows you to put much more items on a single disc.As the format of the files is not changed, the quality of the files remains the same.
You can burn a data CD or data DVD in Windows 7 using Media Player as follows:
  • Click Start.
  • Click All Programs.
  • Select Windows Media Player.
  • Click the Burn tab in the Player Library.
  • Click Burn options and select Data DVD or CD.
  • Insert a blank disc into the CD or DVD burner of your computer.
  • Close the AutoPlay dialog box if it comes into sight.
  • Some people have more than one CD drive in their computer. If you have multiple CD drives in your computer too, select the one you would like to use in the navigation window.
  • Look for the songs you want to burn.
  • In order to make your burn list, drag the songs from the details pane in the center of the Player Library to the list pane which is on its right side.
  • You can also change the order of the items in the burn list by dragging them upward or downward in the list.
  • To remove a song from your list, simply right-click on the item and click on Remove from list.
  • After you finish making your list, click upon Start burn.
It can take a while to burn a data disc. If your selected items cannot fit in one disc, you also have the choice of burning the rest of the items to a different disc. A data DVD is not the same as a DVD-Video disc ex. the movie DVD you buy or rent from the store.
on Apr 15, 2010 | Computers & Internet
In burning processs we rec error power calibration error
There are two possibility can cause this :
  1. The problem with your DVD drives. If you are on PC make sure power socket and data cable is connected properly.
  2. Usually DVD drives are picky with the quality of discs, so you can use different discs with better quality.
Aug 06, 2011 | Computers & Internet
Plays fine on both decks, but does not record in any mode.when press rec, the indicator switched from saying "blanc disc" to "data disc" i got this deck used last year. not sure if it...
Check if the blank disc you are using is compatible. It sounds like the discs you are trying to record onto are not compatible with the unit OR you are trying to record in the wrong mode (Synchro v direct see below) It will only record onto CD-R or CD-RW discs. Also read the instructions for recording as there are a number of recording modes depending on menu settings.
See manual here http://www.google.co.uk/url?sa=t&source=web&cd=2&sqi=2&ved=0CCMQFjAB&url=http%3A%2F%2Fmedia.zzounds.com%2Fmedia%2FRCDW500C-be7b6d8b3a46898dae1be148e1af5402.pdf&ei=3eIsTcisNI7sOce8hakK&usg=AFQjCNGCxcLKQKViw1TVJPh_baxuXkVKQA
Jan 11, 2011 | Sony RCD-W500C 5-Disc CD Recorder
For sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
Jul 20, 2010 | Sony RCD-W500C 5-Disc CD Recorder
How can i open a recordable maxell disc? when i put it in my laptop, there's no indication that the disc was inserted, the light was blinking but it also stops in just a while and when i open the MY...
check with any other company rec disc,, the prob might be with the lens or the drive,have u installed the s/w for burning disc eg. Nero,open the disc with the nero
Apr 10, 2010 | Maxell CD-R 80 Minute 700MB Media...
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Recording Problems!
You may try a different style DVD disc. Are you using (+), (-), or (RW) the DVD makes a difference. http://pdf.crse.com/manuals/2636511113.pdf Here is the manual for your product. Check pages 9 and 10. These pages tell you the type of DVD disc to use, and what speed they can be used. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Not recording
You need to use an audio CDr, data or computer CDr's will not work in this machine.
Feb 28, 2007 | Sony RCD-W500C 5-Disc CD Recorder
Sony RCD-W500C 5-Disc CD Recorder Logo
399 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
