Question about Nintendo DS Console
DS wont turn on
My daughter dropped her beloved DS onto concrete from about 3 feet, no physical damage, but wont turn on. The power light comes on but no screen or sound. I have pulled it apart but can not see anything wrong, put back together, same problem. Could it have dropped its firm ware load and if so can I reload it.
I would appreciate an help or comments whatsoever. Thanx
  • 2 more comments
  • KingArtix May 15, 2008
    I dropped my Ninendo ds and it won't turn back on what do I do
  • heart_freyaa Dec 07, 2008
    My DS has taken quite a few bashes since I fall asleep leaving it on my bed and then get woken up by the sound of it crashing on the floor. This happens quite often but I dropped it from about a foot off the ground the other day and now it won't turn on. The charge light works which shows its not out of battery and I can hear something rattling inside...no green light or flash of screen, it just does not respond.
    Help!
    x
  • ggd07_gerasi Dec 07, 2008
    can you help me with this
    http://www.youtube.com/watch?v=cXWgaSAMH...
  • Anonymous Jan 03, 2009
    I have the same problem - daughter dropped onto floor - now it won't turn on
Ds is not good
Posted on May 14, 2008
Nintedo Ds Wont turn on! Even if Charged!
Does the yellow light come on when charging? Could be that the fuse for the charging circuit has gone, or on of the screens has been damaged. If it's only 4 months old and not been dropped etc, send it back to Nintendo I'd have thought.
May 24, 2010 | Nintendo DS Lite Console
Hi my battery won't charge on my Sony Mavica...daughter dropped it about 2 feet onto carpet...charge light is flashing
the charge light flashing means the battery is damaged or very dead .. some charger will not initiate charging if the voltage gets too low ..thats a safety feature ... if those are the original batteries then they are past due for replacement anyhow ..
Jan 19, 2010 | Sony Mavica MVC-CD500 Digital Camera
My daughters dsi is on, but wont turn off. The
Hold the power button some time, the system must turn off.
Oct 06, 2009 | Nintendo DS Lite Console
Dropped Nintendo DS Lite on wooden floor - NOW IT WON'T TURN ON
remove the battery for a few mins and put it back in and try again?
Its a long shot but theres very little you can do with this, the insides of the DS lite are REALLY small and the only replaceable parts are the screen, buttons, etc. and you cant really fix damage to the board or chips inside which presumably is whats happened here if you get zero response.
Sorry.. :(
Nov 13, 2008 | Nintendo DS Lite Console
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Broken nintendo ds
try calling nintendo they might fix it but i do not know what they charge
Apr 30, 2008 | Nintendo DS Lite Console
Dropped ds, now it wont turn on.
It sounds like it got dropped in water but if you didn't; You should try to take out the battery (unplug the DS first) usually I would suggest just waiting a few seconds and replacing the battery. However due to how the battery comes out, and depending on the height the battery fell from, you should make sure none of the brass pinns that contact the battery got smushed.
If the pins are smushed (if one or two of the pins don't protrude as far as the other) take a safety pin or a needle and try to gently bend them back out to a distance they will definatly make contact with the brass strips on the battery.
Apr 14, 2008 | Video Game Consoles & Games
Nintendo ds lite wont turn back on
Not sure if this will help you, but my son dropped his on to a concrete pavement and it wen black, the charge lite would only come up for one second then go out when I plugged it in to charge. Just for fun, I had a spare battery and changed it. In this instance, the system started working again.
Not sure how this can happen, but dropping it on the floor seems to have killed the battery that was in it. A simple replacement battery did the trick for me.
Good Luck in fixing yours
Jan 02, 2008 | Nintendo DS Lite Console
Ds lite
Components may have come loose on the board, or damaged solder joints. Water damage can sometimes only appear after water has had time to seep, unless knock helped throw some residual water around inside, onto things it shouldn't touch.
Dec 02, 2007 | Nintendo DS Lite Console
Dropped the unit, doesn't fully power on now
You would first have to open up the unit and look carefully and see what is maybe broken or out of place. Look for loose connections. Check damaged parts.
Aug 15, 2006 | Xact Communication XTR7CK SIRIUS Radio...
Nintendo DS Console Logo
90 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
