I think my flame detector is bad. error code is a consistant flash on and off. am i correct do i need a new flame detector? Aquastar 240 fx tankless water heater/gas
    Master:
    Sergeant:
  • 449 Answers
Sounds like your right
Posted on Sep 08, 2010
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
E9 error code
Before calling service technician, copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Bosch_E9_troubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
You should delime water heater once per year to prevent many common error codes.
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
Aug 23, 2012 | Bosch AquaStar 2400ES-NG
It often flashes ea or af and doesnt want to light
Before calling service technician, open following links for troubleshoot resources including common error codes, Bosch contact information, link to service manuals, and possible product manual
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Call Bosch 800-642-3111
Multiple error codes can mean PC board failure.
AF might be A9, but not sure.
EA is 'no flame ionization detected with water flow'
  1. Verify that all manual gas shut off valves are open.
  2. Check gas type.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Check three wire connections to ignition group on the lower front of the heat exchanger are secure.
  5. Check gas pressure.
  6. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod.
  7. Check that the minimum power fan speed has been adjusted to the proper value.
  8. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Aug 11, 2011 | Bosch AquaStar 2400ES-NG
Looking for a flow sensor for Bosch Aquastar 240 FX
Open following link for Bosch tankless troubleshooting resources including parts, Bosch contact information, typical manuals, error codes, tech support, fuel-saver calculator, water heater forum, fixya links, disclaimers, and for finding service technician.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 16, 2011 | Water Heaters
Looking for a flow sensor for Aqua Star 240 FX
Here it is..
http://www.lowenergysystems.com/b2c/ecom/ecomEnduser/items/xt_itemDetailNF.aspx?itemNum=EK034&siteId=1&bulkexists=0
The Tagaki TK-1 is the same unit and the parts are interchangeable...
heatman101
Mar 16, 2011 | Bosch Water Heaters AquaStar - Tankless...
I have a Bosch Aqua star 240 fx tank less water heater. The unit will ignite and run for 5 sec (Flame visible through window) the flame goes out and it reignites and runs for 5 more seconds and again goes...
It sounds to me like you tried about everything I would. So I think you're already thinking about what I would do next. Try the flame sensor,and as last resort check all connection . Remove wires one by one clean and reattach. If all else fails change cotrol board. It's very hard to fix when it's not consistent. Good luck. Thanks
Nov 15, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Charmglow ventless fireplace. When I light the pilot the furnance will run properly until it reaches temp. then it shuts off the pilot goes out and requires relighting if it relights. I took your...
In any gas heating appliance there will be a thermocouple that sense if the pilot flame is lit (lighted?).
You bypass this with the regulator by holding the button temporarily and that allows you to light the main burner. If the thermocouple is bad (not uncommon- they sit in a hot seat all the time), it will disable the gas supply.
The thermocouple should normally measure nearly zero Ohms on a multimeter; if it doesn't, it's bad.
If the thermocouple checks out OK, then the regulator has failed.
Oct 24, 2009 | Terminator Aquastar 125FX Tankless Water...
Bosch SX 250 tankless water heater will attempt to fire 3 times then EA code. I have spark through viewing window. Read troubleshooting manual. Says Check ionization electrode. There is no part in the...
This is also known as a flame rectification sensor. It basically is what the computer board uses to detect if the pilot flame is lit. When it makes an attempt to fire is there any evidence of flame ignition? This error does not mean that the sensor is bad for sure. The error could be caused because the water heater is only making three attempts to fire and then shutting down. These water heaters are very complex and have many sensors,valves, ect that are all controlled by a computer board. Some of the basic things to check for are... Make sure that you have plenty of gas pressure. These units have a built-in pressure switch and will have issues if they are starved of gas. Most of these tankless water heaters are up to 400,000 btus and a half inch gas line or undersized connector won't work well. You can also check and make sure there is no pipe dope are debris stuck in the screen inside the gas line where it enters unit. Inspect the pilot assembly for debris or obstructions and try to blow out with compressed air. Also look for any loose electrical connectors on the board or to the sensors...one may have come loose.
Sep 07, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aquastar 125b ng
Replace the thermocouple.
Thats the flame sensor.
If the gas valve is not sensing flame it will not stay lit.
T-couple's are about 9 bucks.
Nov 06, 2008 | Bosch AquaStar 2400ES-NG
Tankless water heater
What error code do you get? I listed the Bosh telephone number below. They should be able to walk through it with you and diagnose it. Be prepared for long hold times though. I also listed the web site. There you can download the manuals and such. Good luck.
1-800-642-3111
Apr 19, 2008 | Terminator Aquastar 125FX Tankless Water...
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
