Question about Frigidaire FRS23H7CS Side by Side Refrigerator
On my Frigidaire Ref/Frzr Model number FRS6LR5ew5-Ice maker is not working???
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 12, 2010
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
Frigidaire side by side ice maker not working
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 16, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
FRIGIDAIRE MODEL FRS24ZGE 24.2 C.FT SIDE BY SIDE DOOR FRIDGE. ICE MAKER IS NOT MAKING ICE AT ALL? CAN U PL HELP?
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 13, 2011 | Frigidaire Refrigerators
Frigidaire Model# FRS6LR5EW5 Frig is leaking on floor, bottom back of unit.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Frigidaire Refrigerators
We have a four month old Frigidaire Gallery FGHB2844L fridge. We love it other than the fact the ice maker quits working to frequently. Right now it is not making ice. There is some frost build up on...
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Frigidaire FGHB2844L
On a frigidaire model frs26lh5ds1 side by side prost proof, the ice maker doesn't make ice. the water drips down into the tray and freezes there. any suggestions?
Leo Ponder
imufo2
Jul 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not filling...already turned off ref let set for 3 hours to thaw still not working
Noticed you did not list your model number of
your Kitchenaid Refrigerator. I see a model number KSRD22FKST above your post
is that correct? If yes there are a couple things that may be causing this. If
the ice maker mold/tray is
full of ice and will not
cycle most times the ice maker thermostat Click Here=> KSRD22FKST while there look at item number
27 in photo. That is your ice maker's thermostat that tells the ice maker when
ready to cycle and fill with water again. The part Number is=> 627985
they also request that you order the sealant for ice maker thermostat=
Jan 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Icemaker won't make ice
First, check to make sure you have water pressure at your supply line. (flex hose) If you have pressure and the icemaker is cycling, (arm moving up and down on its own) you most likely have a defective water inlet valve. This is the valve that the supply line connects to. Water is fed to this valve through your flex hose and then passed through a solenoid to your icemaker when the solenoid is energized.
Mar 04, 2008 | Refrigerators
Frigidaire FRS23H7CS Side by Side Refrigerator Logo
416 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
