Question about Toshiba TDP-S20U Multimedia Projector
Request for the help with Tosiba S20
I have a problem with this projector. After including the power supply ON/STAND BY is shining sie yellow . After pressing the stand-by they are lighting sie FAN diodes and LAMP too green (they aren't flickering but they are shining) lasts for it ok 15 seconds and next is turning into the stand-by and and then again from the beginning the same still around two or three times. The lamp isn't starting. What can be not this way? I am calling for help
Looks like you are having a ballast issue
projector needs to be serviced
Posted on May 14, 2008
How to install maystar s20/50
Maystar s20-50 connections.
Red + to permanent supply via 15A fuse
Black - vehicle body earth wire
Pink - negative trigger input, connect to additional earthing (pin) switches for bonnet boot etc.
Violet - for connection to negative switched courtesy light door switchs
Blue - ACC wire connect to an ignition switch positive supply
Yellow- connect one yellow wire to the left indicator and the other to the right inicator. Ensure that you connect to the switch output to the bulbs, not the supply to the switch.
White - Current sense loop- cut for current sense leave intact for non current sense.
Green - Antenna wire must not be cut or terminated.
Quick connect, for connection to additional Maystar control modules and sensor systems, follow the instructions supplied with the additional sensor.
Jan 16, 2013 | Cars & Trucks
seems like the blue polarizer is overheated. you would have to check out inside the optics to see if the light that enters the blue lcd is coming from the overheated glass plate just in front of it.
Apr 04, 2011 | 3M S20 Multimedia Projector
We have a 3M S20 multimedia projector which is giving off a pink light.
Try replacing input cable or recheck that it's seated properly. (loose/bad cable will produce similar symptoms)
Mar 08, 2011 | 3M S20 Multimedia Projector
My 3m s20 projector has a big yellow spot in the middle of the screen even without a video signal. changing lamps did not help.
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may have to replace the whole optical engine.
Nov 23, 2009 | 3M S20 Multimedia Projector
I get a flash of light and then the projector turns itself off. I have replaced teh bulb but not result
the power supply is bad. the lamp will light, but once the dmd turns on (and the light starts to shine out), it's drains the power and shuts down the lamp. replace the power supply.
Aug 07, 2009 | InFocus LP70+ Multimedia Projector
Not turning on.
can not get it to turn on the yellow lite is on every now and then after playing with it i get it on and it is a good pic i do i get it on or out of stand by mode?
Jan 11, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba dlp s20 projector
both of you have fan and cooling issues. The fans are dirty and that is why they whistle. Try dust off or highly compressed air and blow them out really good and long. This should help. BTW the life expectancy of the projectors are avg. 5000-6000 hours total lifetime.
Jan 03, 2008 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP-S20U Multimedia Projector Logo
385 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
