Question about Apple iPhone Smartphone
Why wont my iphone let me in ? it was jailbroken at first and then i restored it now it wont let me see the home screen ?
You need to activate the iPhone first by putting in a valid SIM card and plugging it into iTunes. Then the home screen'll show up.
Posted on Sep 08, 2010
How do I restore my iPhone 5 with my icloud account password?
Hi, make sure you have a backup of all of your files in iCloud first and to do this from your iPhone, just go to Settings >> iCloud >> Storage & Backup >> then tap "Backup Now"..............You can now do a restore, via the Settings >> General >> Reset >> Erase All Content and Settings (This only applies if your iPhone is not Jailbroken, if your iPhone is Jailbroken, there's a different procedure for that) Once you're done with the restore, "Setup your iPhone" screen will appear and just tap on the "Restore from iCloud backup".
Sep 09, 2014 | Apple iPhone 5S
My iphone wont turn on
Your phone has locked it's self, you need to plug it into your computer and do a restore using itunes, This is common if the phone has been jailbroken.
Mar 05, 2012 | Apple iPhone 3G
The bottom half of my touch screen wont respond to touch, i cant unlock it but it will allow me to turn it off, any solutions?
if part of your screen isnt responding to touch then it could be either software or hardware related, best thing to do it back everything up via itunes and if jailbroken cydia stuff through aptbackup, then do a restore in itunes (if jailbroken shift+restore for custom firmware)
Then once it has finished see if this has corrected the problem.
If not, then you have a fault with your digitizer. This is basically a film behind the glass of the screen which tells the iphone where you fingers are etc.
You can buy a new digitizer pretty cheap from ebay, just look up a guide on how to install it (you can keep your exisiting LCD) and this will fix the problem.
Apr 09, 2011 | Apple iPhone Smartphone
I erased all content and settings on my jailbroken iphone 3g and now its stuck on the start up screen
Plug the iphone into your computer and restore the phone using itunes. If the computer won't recognize the phone put it in DFU mode by doing the following.
1. Hold the lock/unlock button for 10 seconds. 2. Continue holding the lock/unlock button and also hold the home button for 10 seconds. 3. Release the lock/unlock button and continue holding the home button for 10 seconds.
After the connect to itunes screen appears on the phone, plug it in and attempt to restore again.
Mar 08, 2011 | AT&T Lands Phones
I unblocked my iphone and know it asks me to connect to itunes and how do i do that
its stuck on recovery mode
plug iphone itunes
then hold the home and middle button for 10 seconds.
then on itunes its gunna gonna tell u to restore iphone
then it should be jailbroken and good.u wont lose any data when you restore it
Oct 06, 2009 | Apple iPhone Smartphone
My iphone camera wont even start!
If jailbroken try use different .ipsw file. Or try Restore.
Sep 01, 2009 | Apple iPhone 3G Black Smartphone
Iphone 3g is frozen and touch screen wont work
If this unit is jailbroken you may want to do a full restore of the device, you will need to get the Iphone turned on and connect it to itunes, when you get into I tune and you phone is seen, right click on the device in itunes and tell it to restore.
This will reset the phone back to defaults, you will loose most of your data if not all.
If you can't get it to stay on or come on in Itunes then you may need to try this.
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Aug 30, 2009 | Apple iPhone 3G
Jailbroken iPhone battery meter goes bezerk during charging
Disable your theme and turn on then off then on (toggle it) the battery % in the settings. The theme can sometimes do screwy things to your phone. I would recommend removing winterboard all together and seeing if that solves the problem. Worse case you will need to restore your iphone. If it comes to that be sure you take screen shots of each app page by holding down the lock and home button for a second or two until you see the flash. They have apps that "backup" your jailbreak apps, but honestly I do not trust them and if you do a fresh install after the restore it will for the better.
A few things to note if you do the restore option:
1. Backup your phone in itunes before you restore it.
2. You will need to jailbreak it again... but it gives you a good excuse upgrade the iphone OS.
3. iTunes backup with not back up any cracked apps you may or may not have installed so be sure you have the files somewhere.
4. Test your battery issue while the phone is not jailbroken after the restore. This will be a great time to take it to the apple store if it is still acting up :)
Good Luck!
Aug 22, 2009 | Apple iPhone Smartphone
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
Jul 24, 2009 | Apple iPhone 3G
Iphone got pineapple logo
Connect to a computer and do this to enter DFU mode and try to restore, be aware that everything on the phone may be lost:
-Turn phone off if possible -Hold power and home together for 10 secs -Release power but keep holding home until computer detects iPhone
Repeat a few times it can be hard to do the first time.
Jun 08, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
29 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
