Question about HP PSC 1210 All-In-One InkJet Printer
Will not pick paper up to print - HP PSC 1210 All-In-One InkJet Printer
  • 20 Answers
Some HP printers will not pick up cheaper lightweight paper.
Try at least a 24. lb paper.
Sam
Posted on Sep 08, 2010
Hp officejet 4500 will not print from mac ibook g4
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - The All-in-One Does Not Pick Up or Feed Paper Issue The product does not pick up or feed paper from the paper tray. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. c01733891.gif IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report
  1. Load plain, white paper in the paper tray.
  2. Press and hold the Cancel button (c01235250.gif ) on the product control panel.
  3. While holding the Cancel button (c01235250.gif ), press the OK button (c01961874.gif ). The self-test report prints.
NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Reset the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button (c01602202.gif ) to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the test page prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the test page does not print , continue with the next solution.
Solution two: Check the paper The condition of the paper or the amount of paper loaded might prevent the rollers from picking it up and feeding it through the product. Use the following steps to check the paper in the input tray.
  1. Remove any wrinkled or damaged paper from the input tray.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper contains from 10 to 25 sheets of paper.
    NOTE: Do not overload the input tray. Make sure the stack of paper is shorter than the top of the paper width guide.
  5. Insert the stack of paper into the product, and then gently push the paper width guide snugly against the paper. Figure 1: Load paper c01970609.gif 1 - Load paper 2 - Adjust the paper width guide Illustration of loading paper and adjusting the paper width guide
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Check the print settings The paper settings in the print driver must match the paper size and type loaded in the product. Use the following instructions to adjust the paper settings.
  1. In the software program you are printing from, click File .
  2. Click Print , and then click Setup , Properties , or Preferences .
    NOTE: The specific options might vary depending on the software program.
  3. Click the Features tab.
  4. In the Basic Options pane, select More from the Paper sizes drop-down list.
  5. Select the size of paper loaded in the product, and then click OK .
  6. In the Basic Options pane, select More from the Paper type drop-down list.
  7. Select the type of paper that you loaded, and then click OK .
    NOTE: These changes do not change the default print settings. The print settings revert to the default settings the next time you open the program.
  8. Change any other print settings necessary, and then click OK .
  9. Click OK to print.
  10. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Clean the rollers Follow these steps to clean the rear rollers and the pick rollers on the HP product. Step One: Clean the rear rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 2: Remove the rear access door c01961876.gif Remove the rear access door
  4. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the paper rollers. Rotate the rollers with your fingers to clean all the way around. Figure 3: Clean the rollers c00246512.jpg Graphic: Showing paper rollers
  5. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely. Figure 4: Access door rollers c01590938.gif Access door rollers
  6. Allow the rollers to dry completely.
  7. Reattach the rear access door. Push the door forward until it snaps into place.
Step two: Clean the pick roller
  1. Remove any paper from the paper tray.
  2. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 5: Remove the rear access door c01961876.gif Remove the rear access door Figure 6: Rear rollers and location of pick roller c01976220.gif Image: Rear rollers and location of pick roller
  3. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the pick roller. Rotate the pick roller upward with your fingers to clean all the way around. Figure 7: Pick roller c01975068.gif Image: Pick roller in the product
  4. Make sure that the pick roller and the rollers around it are clean, free of paper bits, and rotate freely.
  5. Allow the pick roller to dry completely.
  6. Reattach the rear access door. Push the door forward until it snaps into place.
  7. Load the tray with plain white paper.
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button (c01602202.gif ) to turn on the product.
Solution five: Service the All-in-One
Mar 06, 2013 | HP Officejet 4500 All-in-One Printer G510G
Paper jam p1005 hp printer
Load paper, give print command verify weather pick up roller trying to pick paper?.. >if yes check pick up roller surface feel smooth?, replace it.. >if no remove right,left and back covers, check solenoid jammed? release it.shoot print command check> if solenoid not acting replace it and verify..
Jan 09, 2012 | HP Office Equipment & Supplies
It sends a message of paper jam but the real problem is that it wont pick up the paper to print it And then send the code 075-134
Most printers have rubber wheels that pick up paper. These sometimes get caked up with paper dust and stop picking up paper. Take a cloth with rubbing alcohol and wipe the wheels. Once they're clean, try printing again.
Apr 22, 2011 | Office Equipment & Supplies
My xerox 3119 frequently pick up more than 1 paper during printing. It cause paper jam and make it very hard to print of both side of the paper. Can you help me solve this problem?
The xerox laser printer rollers have shrunk, causing the paper to be picked up in multiple.
Try to fan the paper before adding it to the paper tray.
Aug 11, 2010 | Xerox WorkCentre 3119 Laser Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
Paper will not feed to be printed
THERE MY BE OLD ON THE PRINTER PICK UP WHEELS CLEAN WITH ALICOLHAL,
TRY SOME DIFFERENT PAPER THE PAPER MAYBE CHEEP PAPER THE MATERAIL OF THE PAPER MY BE MADE DIFFERENTLY AND THE PRINT DOESNT LIKE IT
ROD
Jan 29, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
