Question about Toshiba TP61H95 61" Rear Projection Television
Screen blanks out, no picture and the red light next to the power light blinks every second or so. If you unplug the tv and plug it back in, the picture returns. Is this a bad power supply.
  • Toshiba Master
  • 5,568 Answers
> Is this a bad power supply. Highly possible; one of the failure modes for 'switched mode' power supplies is a reluctance to start up. This is often caused by the decay of a 20 cent capacitor that should have cost 50 cents. Cutting off AC to the supply can allow the cheap capacitor to recover some of its lost value and do what it should. Asian designers seem to think that doubling the value of an electrolytic will ensure its survival when they should instead buy only parts rated for the type of service some of them see; the cost difference would be small.
Posted on Sep 07, 2010
  • 7 more comments
  • bgetchell Sep 07, 2010
    so how can I confirm the failure mode. The TV generally starts up and then intrmittently loses the picture. Sound is always present. un-plug the TV for a moment, plug it back in and the problem is solved. This has been happening for approximately 4 months.
    thank you... by the way
  • Steve Allison
    Steve Allison Sep 08, 2010
    It's helpful when folks mention not only the problem they have but the problem they don't have. Since you have sound, the main power supply is probably not a fault.
    The projection CRTs use high voltage in their operation, so the problem is likely related to an intermittent failure in the separate supply that provides the high voltage.
    I suggest you pull the unit away from the wall and then pull the AC plug and let the set rest overnight to allow residual voltages to discharge.
    Remove the lower panel to gain access to where the electronics are customarily found.
    The first thing you might want to try is to remove and re-plug and beefier connectors you see, particularly those that interconnect separate assemblies, paying special attention to smaller boards that are populated with larger components; these will be power supplies and I think you will find two of these.
    One of them will have several in- and outputs, the other, the high voltage supply fewer. This latter one is the one I suspect.
    If you can visually inspect both with a good light source, look around the bases and the exposed aluminum tops of the different-sized cylindrical parts with shrink-wrapped jackets and values such as (example-they vary) 47uF/50VDC. These are capacitors and common culprits in failures such as yours.
    These parts are called 'electrolytic' capacitors and are devices using chemicals that sometimes leak (not supposed to though) if they are failing and will discharge some onto the board on which they are mounted and if the failure is severe, will cause the scored top to split open to relieve internal gas pressure.
    If you see no signs of things described, then you need a trip to Radio Shack or other electronic supply place to secure a couple of cans of 'freeze spray.' This stuff produces -40 F and lower temperatures used for troubleshooting.
    Cooling a weak capacitor can restore it temporarily and confirm the condition of a suspect part.
    A hair dryer can be used to (gently) reheat a suspect part and cause it to fail again and with a couple of cycles, establish that a part is bad.
    Now, keeping in mind that a 'live' circuit can be dangerous, you will need to provide AC to start your search.
    Assuming the video is missing, spray those cylindrical parts, which can vary in physical size from 1/2"H X 1/4"D to as much as 2"H 1"D, the small one with a very short burst, the larger with no mare than ~ 2 seconds.
    Do NOT jump from one to the next; they all have some thermal mass and need time (2 seconds for small, 5-10 seconds for large) to 'soak' and allow the internal warmth to dissipate.
    If you are patient (and lucky) you should be able to find the marginal part.
    If you make it this far and decide you can DIY, comment back and we'll continue.
  • Steve Allison
  • Steve Allison
  • Steve Allison
    Will continue, replies are limited.
  • Steve Allison
  • Steve Allison
    It's helpful when folks mention not only the problem they have, but the problem they don't have. Since you have sound, the main power supply is probably not a fault.
    Will continue, replies are limited in length.
  • Steve Allison
    Tried to respond with explicit instructions but replies are length-limited.
    Please supply an email address to: freetekATlycos.com (make the usual correction.)
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My Sony tv won't power on its goes on then stays blinking on standby 14 blinks on red
Try unpluging the tv for several minutes and then plug it back in and turn it on and see if that helps
May 22, 2015 | Sony Televison & Video
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Toshiba TP61H95 61" Rear Projection Television Logo
151 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
