Question about Frigidaire ATF6000ES Front Load Washer
I have water that sits on the rubber part of my washer, It now has mold in it. I have cleaned it per instructions and there is still oder of mold that won't go away. I think I need to replace the rubber seal but I don't know where to go, who to contact.
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Mold spots on the inside of the rubber seal of the washer... how do i clean remove it/
    two ways to remove the mold one you can either get some vinegar and water or bleach and water and sit with a bucket and a spong and scrub away on the mold areas or you can goto your local home depot and look for a product they sell called AFFRESH which is a product that not only cleans a front load washer it also prevents this mold occurance in the future you may need to use more then one tablet in order to clean you unit if you have never used AFFRESH before if you have any further questions message me back Thanks again Rick
    Feb 13, 2011 | GE WSXH208A Front Load Washer
    Mold in the seal around the door. Bad musty oder from towels.Very disapointed with this washer.
    The mold is coming from too much soap. You have to use HE soap. I know this sounds funny but it's true. I started using less soap as specified by LG after I rinsed the system with water and vinegar a couple of times. But the vinegar in the bleach compartment. I may take a few times to clean the system out but the smell will go away and with continued use of HE soap in small amounts the mold will not return. I never knew mold likes soap scum. Good luck. Give me a thumbs up if this worked for you. :-)
    Jan 03, 2011 | LG WM2277H Front Load Washer
    Mold remain in rubber rim of washer
    Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
    Aug 02, 2010 | Miele W1926A Front Load Washer
    RUBBER LINER COLLECTING MOLD
    I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
    Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Water sitting and mold growing in the rubber gasket ring around the opening for the door
    Front loaders are known for building up mold and the smell.
    It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
    It’s caused by using fabric softener. Dilute it 50/50 with water.
    It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
    Pull the rubber door seal back and clean the mold off .
    affresh is recommended by some manufacturers. You run it through a wash cycle with it.
    Oct 09, 2009 | LG WM-2277HW Front Load Washer
    LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
    Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
    Sep 28, 2009 | LG WM1814CW Front Load Washer
    There is a musty oder coming from inside washing machine.
    Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
    Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
    Good Luck
    Aug 08, 2009 | General Electric WBVH6240HWW Front Load...
    Frigidaire ATF6000ES Front Load Washer Logo
    234 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
