Will the otc 4000 enhanced monitor work on a 03 dodge ram 5.7 hemi...have monitor do ineed special hardware,software... also needoperators manual.
  • 59 Answers
SOURCE: I am getting a p0304 #4 cyc mis fire on my 03 Ram 5.7 hemi
If there is a misfire you do not need the firing order to figure out the fault. Just replace the plugs and go from there. Really no need to sacrifice your time chasing an ignition problem when all you need is a simple tune up , or coil . Rec. Changing all plugs and #4 coil , and have a fuel induction service performed by your local garage or dealer.
Posted on Sep 01, 2009
Testimonial: "Thanks good response"
  • 7353 Answers
SOURCE: 05 5.7 hemi burning 1 qt every 700 miles
does not sound good. how many miles on engine? knocking may be piston slap if it goes away hot. may be engine replacement time.
Posted on Sep 19, 2009
Testimonial: "thanks for help "
  • 249 Answers
SOURCE: replace timing chain on 03 dodge ram 1500 with 5.7 hemi
i have an 02 and i purchased a repair manual from autozone
Posted on Jan 05, 2010
redbeard00
  • 957 Answers
SOURCE: 2006 dodge ram hemi 5.7 liter trouble codes 1404 a...
The check engine light is on to tell you that the ECU has detected a fault. The faults are stored as codes. The codes both have to do with a deficiency of exhaust gas going through the EGR valve. You will need to find out if the problem has to do with the valve, a leak, or the circuit.
Posted on May 22, 2010
SOURCE: 2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Posted on May 26, 2011
2005 Dodge RM 1500 hEMI Lighting Bolt Light staying on. replaced throttle body now the light is blinking
Throttle body needs to be relearned. Need a oem level scan tool or equivalent. (Snap on versus modus) otc genisys or dealer tool. Once this is done the light will quit flashing and the truck will run correctly.
Mar 25, 2015 | 2005 Dodge Ram 1500
I have a 03 Dodge Ram 2500 Hemi 4X4 that is making a very loud knocking sound in the frontend when I turn left, or right.
check the cv axles at the front differential. inner joints get loose on the splines and cause a knocking noise.
May 16, 2012 | 2004 Dodge Ram 2500
Need cylinder 6 for replacing plugs 2500 03 5.7 litter hemi
Hi there:
On 2003 Dodge RAM 2500 3/4-Ton 5.7 liter Hemi V-8 VIN "D" check this diagram...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 13, 2012 | Dodge Ram Cars & Trucks
Looking for firing and coil order 2004 hemi 5.7
For ALL 2004 Dodge RAM (1500, 2500, and 3500) (2WD and 4WD) 5.7L V8 Hemi:
.........Firing Order:
Coil...1-8-4-3-6-5-7-2
Plug..6-5-7-2-1-8-4-3
This should have been located at the top of the your Intake Manifold.
Let me know if this helped...
Apr 15, 2010 | 1998 Dodge Ram 1500 4WD
Feb 12, 2010 | 2007 Dodge Ram Truck
Replace timing chain on 03 dodge ram 1500 with 5.7 hemi
Jan 05, 2010 | 2004 Dodge Ram 1500
Aug 31, 2009 | MTX Dodge Ram Quad Cab 2002-2003...
No heat
No heat can mean low coolant in the radiator. Check that. Also would mean you have a coolant leak. Might possibly be a restricted heater core. Possibly a blend door in the dash that quit working. Thermostat could be faulty allowing coolant to flow continuously.
Apr 01, 2009 | 2004 Dodge Ram 1500
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
