Question about Dryers
How do i change a power steering pressure hose on a 2000 maxima
  • 10,865 Answers
Hello. Here is the link to the maxima forum which explains all of the steps for this job. It is a difficult job by the way. J
http://forums.maxima.org/5th-generation-maxima-2000-2003/537063-replacing-high-pressure-pwr-steering-hose-02-a.html
Posted on Sep 08, 2010
The location of the power steering pressure hose
i am attaching an image of the power steering reservoir, the hose that comes after the power steering pump is the side of which there is pressure(that is the power steering pressure hose) the hose that is connected directly to the reservoir is the return hose .
Sep 05, 2015 | 2000 BMW 528i
How to find if the power steering pump or the hose is bad or leaking on a 2000 nissan maxima
check around pump hoses for leeks if the pump is going you should be able to hear the bearings in the pump going or a loud squelling sound
Sep 19, 2012 | 2000 Nissan Maxima
My car is smokeing under the hood what would be the problem
SMOKING UNDER HOOD CAN BE CAUSED BY MANY THINGS.BUSTED OR LEAKING RADIATOR HOSE.POWER STEERING HIGH PRESSURE HOSE RUPTURE GET FLUID ALL OVER HOT EXHAUST MANIFOLD CAUSING SMOKING.LEAKING VALVE COVER GASKETS ALLOW OIL TO LEAK DOWN SIDE HEAD TO HOT EXHAUST MANIFOLD CAUSING SMOKING.ELECTRICAL SHORT CAUSE SMOKE.
Oct 06, 2009 | 2000 Nissan Maxima
Need an digram of 2000 ford focus power steering pump
Item Part Number Description 1 - Steering wheel 2 - Steering column 3 - Boot 4 - Tie-rod 5 - Tie-rod end 6 - Steering gear 7 - Steering gear to fluid cooler hose 8 - Fluid cooler 9 - Power steering pressure (PSP) switch 10 - Power steering pump 11 - Fluid supply hose 12 - Fluid reservoir 13 - Pump to steering gear pressure line 14 - Steering gear pinion extension
Jul 30, 2009 | 2000 Ford Focus
My 04 maxima is hard to steer .fluid is full no leaks is not making any noise. what could it be.
the problem with this hard steering, is the lower steering shaft to the second u joint. and it is a lot cheeper than a steering rack.
Apr 16, 2009 | 2000 Nissan Maxima
Leeking power steering line on a 93 NISSAN Maxima
We recently changed the power steering line on our 93 Maxima. Bought the hose from Advance Auto Parts. No problem.
Nov 17, 2008 | 1993 Nissan Maxima
Squealing power steering. It is hard to turn car without squealing.
Is the power steering fluid at the proper level?
Is the belt worn or loose? Follow hoses from power steering to the pump which is connected to the belt. Google worn belts or belt tension for details.
Jul 15, 2008 | 2000 Nissan Maxima
Dryers Logo
90 people viewed this question
Top Dryers Experts
